![]() Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
LT5 95mm TB
Which would be better? Portted stock 87mm throttle body or unported lt5 95mm TB? Weapon X offers the lt5 TB for the fair price with adapter.
![]() Drives: Camaro Join Date: Jun 2018
Can you run a 95mm throttle body without a tune?
I think so. Not really sure though? People on here have done more than that without one. Right now only "performance mod" is roto-fab intake and catback exhaust borla Stype
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I would go with a stock TB that is ported. Then there won’t be concerns if a tune has to be done or it won’t bolt on to the intake without an adapter. That’s my 2 cents worth!
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Just a guess, I would think in order to take advantage of the increased flow the larger TB would require a tune.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
I guess my thoughts are if I was to possibly port anything on the snout or supercharger I could just use the same TB. I also read somewhere that the opening of the snout is slightly larger than the 87mm TB. Maybe I read too much
#7 |
#8 |
Stock size ported by TM. Some feel no difference, some do. I felt noticeably sharper throttle response. But then the rest of the mods came along a month later so I only had just the TB for a short time.
#9 |
Intimidator has his NX lid for sale too. I might pick that up and a katech ported TB. Just when I thought I was done for a while with mods
#10 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
to get the most out of the LT5 TB, it would require a tune.
#11 |
So you definitely would need a tune with the 95mm lt5 tb but is it worth it. Or do you get enough from the stock size ported
#12 |
![]() Drives: 2016 CTS V Join Date: Feb 2012
You dont need a tune. You will make gains, but if your not going to port the snout then no reason to go to the 95mm as the snout will be your bottle neck and keep your gains down.
#13 |
#14 | |
BUT with those mods you will feel the difference and look stock if you ditch the Rotofab and the pulley. And at a comparatively low price compared to bigger plans.
