Old 04-03-2019, 11:31 AM   #1
Conekiller88
Drives: 2008 Evo X
AirBag fuse pull ?
As many of you probably saw the ZL1 AutoX airbag video I need to know if there was an update on this subject.
I was also wondering if you could just pull Airbags fuse for the autox day to have a peace of mind that they wont go off if you spin out.
Let me know how to approach this issue .
Conekiller88 is offline   Reply With Quote
Old 05-10-2019, 12:00 AM   #2
rck329
rck329's Avatar
Drives: 2016 1SS
Just found the AutoX video as well as this one:
Was wondering the same thing... don't need a $4-6k bill if I happen to curb a little too hard at the track.
rck329 is offline   Reply With Quote
Old 05-10-2019, 02:17 AM   #3
JeromeS13
Drives: 2017 1SS/1LE
I would definitely recommend NOT disabling the airbags on a road course, unless you have a full cage, racing bucket seat, and 5/6 point harnesses....
A low speed autox is one thing... A high speed road course is completely different... They're there to save your life...
Old 05-21-2019, 06:42 PM   #4
Move_Over
Drives: ISO ss 1le
Originally Posted by Joey Soul View Post
His driving style is actually annoying. Who racing on a track with 1 hand on top of the wheel and other one doing nothing at all.
He is handicapped.
Move_Over is offline   Reply With Quote
Old 05-23-2019, 07:14 PM   #5
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I've been told pulling the fuse DOES NOT keep the airbags from going off. They store just enough energy to deploy just in case power is cut in a crash. I found this with a quick search:
Even after disconnecting the battery there is no guarantee that the airbags have been deactivated. As mentioned before the capacitor can hold a charge up
to 30 minutes. The length of time each model of vehicle will hold a charge varies from 0 seconds to 30 minutes. Even after the capacitor has been discharged
there are several factors that may allow for discharge of the airbags.
Old 05-29-2019, 11:24 AM   #6
L8Apex
Drives: 2016 2SS
One hand on the wheel, then stops in the middle of the track, flipping idiot.
L8Apex is offline   Reply With Quote
Old 05-29-2019, 01:24 PM   #7
JeromeS13
Did you read the comments? He doesn't have use of one arm...
