Old 04-02-2019, 09:22 AM   #1
Charlie540i
Drives: 2016 Camaro SS
Anyone with a Whipple and a lower damper?
I'm looking for people who have used a Whipple in a cammed, ported heads, 2.0" long tubes and full exhaust with a 9.17" overdrive lower to check upper pulley combo and boost level.
Lets say lower 9.17" or larger with a 3.50", 3.25" or 3.62", how much boost are you getting from those pulley combinations with a Whipple on either a LT1 or LT4?
Charlie540i is offline   Reply With Quote
Old 04-02-2019, 09:46 AM   #2
Hilltopper
Drives: 2018 Camaro ZL1, 2017 Z06/Z07
I have a 9.17" lower and 3.5" Upper. 12 lbs of boost with LME 10.5:1 setup. Headers are 1 7/8".
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1
Hilltopper is offline   Reply With Quote
Old 04-02-2019, 09:56 AM   #3
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Guessing the 8.4 and 9.1 are fairly new. When I did mine they only offered the 8 which I installed. Went from an upper 3.125 and 7.0 to a 3.500 and 8.0 combo. That change kept my numbers pretty close (whipple speed from 14560 to 14857 @ 6500RPM's). AEM boost gauge shows low 13's with my setup. What drove me to this was belt slip though which it resolved.
I believe for about every 550 increased in blower speed equals about 1 PSI. So if I were to have a 9.1 and a 3.500 I would expect to see about 3.75 more PSI (17PSI)
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 04-02-2019, 09:59 AM   #4
Joe's_cool_1le
Interesting. I must be missing other factors because I'm making more boost with a smaller lower with a pretty close setup.
Ahh... I'm still on a stock TB. And you look to be moving air much better.
Old 04-02-2019, 11:21 AM   #5
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
I don't know what the boost was, but when Jannetty was going through my car they tried an 8" lower to go with my 3.625 upper (Version 2 whipple) and it basically ran out of fuel - 650 wtq before it got into knock retard and they abandoned the run.
I think the version of the Whipple has something to do with you having more boost on less pulley.
On 7" lower and 3.625 upper I'm at 9.8 max boost with an average of 6.8 across the dyno pull.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 04-02-2019, 06:40 PM   #6
Hilltopper
Actually......I stand corrected. 9.17 lower and 3.75 upper. I forgot we changed uppers from 3.25 to 3.75 when we swapped lowers. The 3.25 with 9.17 made too much boost for my setup. Ended up with around 12 lbs of boost with the 3.75.
Old 04-06-2019, 11:29 AM   #7
Charlie540i
Thanks for the replies. I'm working on a 2018 ZL1-1LE and using a 9.17" lower and a 3.25". I haven't got it on the dyno yet to do more controlled testing, but so far the MAP readings are really high when I go WOT juts in 2nd and part of 3rd gear.
Just comparing with you guys, as per Whipple I should have 15psi and I'm seeing a lot more than that. Well, at least according to MAP.
Old 04-09-2019, 07:48 AM   #8
Hilltopper
That's exactly the same problem we had with mine. The 3.25" upper on the 9.17 lower made WAY more boost than it was supposed to. If I remember correctly, the run was aborted in the 5,500 rpm range with boost climbing way past where they wanted to be (17+ if I remember correctly). They changed the pulley to the 3.75 and settled on the 12ish psi. Much better belt wrap, as well.
Old 04-09-2019, 10:05 PM   #9
GT-ER
I have a 9.10 lower and 3.75 upper and make about 15.5psi but I'm on stock cam.
GT-ER is offline   Reply With Quote
Old 04-10-2019, 11:32 AM   #10
Charlie540i
Talked to Whipple, there was a communications problem... to get 15psi with a 3.25" is when using a stock 7" lower. When using a 9.17" lower and the 3.25" I was seeing 20-21psi at just 4k-4.5k rpms.
Was suggested to try an 8" lower or a 4.0" upper to get around -4-5psi.
Old 04-10-2019, 07:47 PM   #11
GT-ER
If you already have a 9.17 lower, just use a 3.75" upper and you should be at around 15psi with your setup.
Saludos Charlie!
Old 04-11-2019, 03:07 PM   #12
Charlie540i
Saludos Charlie!
I'll try the 3.75"....
Yo sabia que habia visto ese nombre antes! Saludos!!!
Old 04-11-2019, 07:00 PM   #13
GT-ER
LOL.
Old 04-14-2019, 10:57 PM   #14
mauldin44
Drives: 2017 Camaro SS 50th Edition
I'm running a 9.1 lower and 3.25 upper hitting about 18-19PSI of boost on a Whipple. I'm running Meth and E85 as well. I've learned with swapping pulleys to get boost numbers up or down it's kind of an art versus an exact science. Two cars can have the same pulleys, but vary on boost levels.
mauldin44 is offline   Reply With Quote
