04-01-2019, 07:09 AM | #1 |
Drives: Summit White 2018 Camaro 1SS M6 Join Date: Jul 2018
Issues after installing cold air intake
I've installed K&N Cold air intake (63-3092) and since then I've noticed several issues pop up that were not there prior to install.
1.) Really bad rev hang, if I rev the engine in first or reverse it will hold at like 2-3k RPM's. If I rev it up while clutched in or in neutral, the revs will drop very very slowly. 2.) Power loss, I've noticed that the car feels far more sluggish and this was evident when I did a 40 roll with a bud's Focus ST and I was neck to neck with him rather than flying past him like I used to. 3.) Radiator Fan comes on randomly at full speed every once in awhile. Any ideas as to a possible fix for these issues? |
04-01-2019, 07:47 AM | #2 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
I have not installed a cold air intake onto a fuel injected engine, so I do not have any first hand experience with this.
However, with your symptoms it sounds like you have a vacuum leak (false air) entering the system like an intake gasket leak or a vacuum hose not connected properly. This would typically cause the revs to hang. Otherwise, you will need a tune. But others may be able to chime in here if that is neccesary. |
04-01-2019, 07:51 AM | #3 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
did you get any codes? i've seen where people didn't install it correctly like on the throttle body or MAF sensor, recheck and go from there.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
04-01-2019, 07:56 AM | #4 |
I would check for leaks first. Make sure all your fittings are secure and tight.
04-01-2019, 10:29 AM | #5 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Vacuum leak or your filter is over oiled.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
04-01-2019, 11:31 AM | #6 |
No codes, have unplugged and replugged MAF sensor multiple times. Will check again for any leaks
04-02-2019, 07:53 AM | #7 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Did you disconnect the negative battery terminal before you unplugged the MAF sensor?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
04-02-2019, 08:22 AM | #8 |
I did not, thinking back this might of been my dumb mistake.
04-02-2019, 09:01 AM | #9 |
Drives: 2016 Camaro SS Join Date: Sep 2018
04-02-2019, 01:22 PM | #10 |
get a tune a cold air intake isnt going to do much alone
04-02-2019, 02:33 PM | #11 | |
Actually it can, on the 6th gen cars there are several modules that stay online and active. The MAF can trip errors if unplugged while the ECM still has power. I never used to pull the battery, but now I do on the 6th gen due to random errors when sensors are unplugged while the battery is still connected.
04-02-2019, 02:34 PM | #12 |
Check your throttle body bolts/gasket.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
04-03-2019, 07:16 AM | #13 |
@Tjay74 how do I check if it is the MAF sensor? And if so, how can I resolve it? I have checked for any leaks, tightened all my bolts but the problem still persists
04-03-2019, 08:39 PM | #14 |
Cant really check it unless you have something like HP Tuners, otherwise you can have the auto parts store check for codes.
Only other option is to put the OEM air kit back into the car.
