Old 03-30-2019, 08:48 AM   #1
coodaone
Drives: Red Z28, Grey Z28
Drag Racing wheel and tire combo
I have a 2018 ZL1 A10. Does anyone have a wheel and tire combo size and manufactures?
coodaone is offline   Reply With Quote
Old 03-30-2019, 10:02 AM   #2
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
If you can, just give these guys a call:
http://carlyleracing.com/
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 03-30-2019, 10:27 AM   #3
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Do you want to go with a 15 inch setup on the rear? if so you need to change some stuff. If you dont want to change anytime a 17 inch rim will work on the back and an 18 inch rim on the front. This front tire is impressive as well... you would think a skinny front tire would handle like crap! These are awfully good!
Here is what I did and it worked well;
Rear Rim:
https://www.summitracing.com/parts/RCE-92-795252DSD
Rear Tire;
https://www.summitracing.com/parts/MTT-3572
Front Rim;
https://www.summitracing.com/parts/rce-92-850245dsd
Front tire;
https://www.summitracing.com/parts/mtt-6688
2018ZL1 is offline   Reply With Quote
Old 03-30-2019, 10:29 AM   #4
2018ZL1
2018ZL1's Avatar
pick of said combo!
Old 03-30-2019, 12:21 PM   #5
staples87
Drives: 2017 Camaro ZL1
Originally Posted by 2018ZL1 View Post
pick of said combo!
That setup looks bad ass! What kind of 60' were you able to get on that tire?
staples87 is offline   Reply With Quote
Old 03-30-2019, 03:18 PM   #6
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
pick of said combo!
I hope you layed a beat down on the car in the next lane.
Old 03-30-2019, 05:46 PM   #7
Fraxum
Fraxum's Avatar
Rear Rim:
Rear Tire;
Front Rim;
Front tire;
OP I did the same thing as 2018ZL1 on the back except I did the 10.5" width. No skinnies for me. Those ET Street S/Ses hook pretty well and aren't too bad on the street @32 pounds. Almost as good of a compromise tires as NT555Rs. But the Nitto sizes are too tall for the ZL1.
If you buy those Drag Stars make sure you lightly grease the barrel of the Special Chevy lugs. Otherwise they are a PIA to get to torque. And I ma told the torque on these lugs should be 90-100 instead of the 140 Chevy recommended. More info in my build thread. But don't expect miracles with the DRs IF you can get a low 1.7 you are doing good. There is even a slight ZL1 A10 bog to protect that expensive diff.
Old 03-30-2019, 09:04 PM   #8
2018ZL1
2018ZL1's Avatar
CAI and ported TB it went 1.69 Torque management is killing it! wont have that issue this year!
Old 03-30-2019, 09:05 PM   #9
2018ZL1
2018ZL1's Avatar
sorry to say I did not!
Old 03-31-2019, 01:22 PM   #10
Fraxum
Fraxum's Avatar
I still have yet to get under 1.7 even on DRs. And my MPH runs from 123-126 at Atco and 124-129 @ Cecil in the same air. :( That does
You going big?
I just won't do LTs on this car and the stock Cat has a 2" restriction from what I understand. So if only someone would make a highflow cat to replace the fronts. I suppose the back cat is less restrictive.
Old 04-01-2019, 05:21 PM   #11
2018ZL1
2018ZL1's Avatar
You going big?
Thats pretty much where I was at on the 60Ft... 1.698 was my best! I am working on some things with Ted J. I am trying E60 with my combo and with the 15% pulley I am running out of fuel! I installed the JMS voltage booster and it still wont keep up! Not sure why I thought I could run E fuels with my combo without replacing the fuel system! I think that will be my next upgrade. I went with the ARH 2 inch no cats back to the stock NPP. Its LOUD!
Old 04-01-2019, 05:49 PM   #12
big dave
Drives: 2017 ZL1
You going big?
TM is the Devil. On my last trip to the track, I ran an 11.05 with a 1.74 60', 11.02 on a 1.70 60', then ran an 11.05 with a 1.66 60' on the stock tires. It appears that TM decided to end the party for what should've been a 10.9? pass.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 04-01-2019, 06:33 PM   #13
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Originally Posted by big dave View Post
TM is the Devil. On my last trip to the track, I ran an 11.05 with a 1.75 60', then ran an 11.03 with a 1.66 60' on the stock tires. It appears that TM decided to end the party for what should've been a 10.9? pass.
You definitely should've ran a 10.95 or better if all other conditions were the same.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 04-01-2019, 06:41 PM   #14
big dave
Drives: 2017 ZL1
I had to double check my timeslips and revise what I posted. I was off by a couple hundreds. I do agree that it should've been at least a 10.95 if the soup nazi (Seinfeld) hadn't shown up. lol
