03-29-2019, 05:13 PM | #1 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Does adding air scoop require a retune?
Will I need a retune when I add my air scoop to my L99? I have LT’s with HF cats and a cold air unit. I’ve been searching the site to find the answer to this question with no success.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
03-29-2019, 07:00 PM | #2 |
Drives: 13' 1LE Join Date: Apr 2012
No. I did it and no it doesnt make enough of a difference to.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-29-2019, 08:32 PM | #3 |
No, the minimal amount of air from a scoop should be learnable without a retune, imo.
I installed a stage 2 PTB today, replacing my stock unit. Idle was slightly off for a few miles and has been driving better all day the longer I drove it. But I did pull the battery for 5 mins before I started the car. If you didn't have ANY tune, then I would think yeah, maybe you should get a tune. But the proof will be after you install it and drive it for a bit. Not all these cars respond the same to mods. But no better time than now to clean your filter and MAF. Every oil change and halfway in between I clean my filter and spray my MAF with CRC MAF cleaner.
