Old 03-28-2019, 09:46 PM   #1
Flashyeezus
SS
Drives: 2018 ss
Camaro ss full e85 oil change?
Every when should i change my oil if im on full e85.i do notice my oil going down much quicker than stock. Im at 27% rn.
Flashyeezus is offline   Reply With Quote
Old 03-29-2019, 12:30 AM   #2
s346k
s346k's Avatar
Drives: like an old lady
i’d change it every 1500-2k miles depending on how often i ran e85
Old 03-29-2019, 07:15 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Why would you have to change your oil more often running E85?
Old 03-29-2019, 08:32 AM   #4
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
Because you get corn kernel residue that slips past your rings in the combustion chamber and go's into your oil feed system.
WCKD 1LE is offline   Reply With Quote
Old 03-29-2019, 08:55 AM   #5
JCunningham
Drives: 2017 2SS M6
so how many miles do you recommend changing it? if its 2000 miles Why would GM say nothing about changing it more often in their flex fuel vehicles?
Old 03-29-2019, 09:10 AM   #6
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
Unless you have e85 seeping into your oil (which you would have bigger problems) I'd stick to every 5K. I've never had a problem using that time frame, and I'm using Motul.
Old 03-29-2019, 09:58 AM   #7
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Toyota for example requires the oil interval to be cut in half when you use E85. (tundra) from 10k to 5k miles.
The rule of thumb is to change your oil twice as often with E85.
Your OLM may not be calibrated to E85 so I would not rely solely on it.
For $25 I'd do a UOA after 4k miles
thescreensavers is offline   Reply With Quote
Old 03-29-2019, 10:15 AM   #8
s346k
s346k's Avatar
i’ve seen a few blow up around here. they were not “flex fuel” engines, more like ls7 strokers and 4g63 motors making 600+ hp. nonetheless, i would err on the side of safety and not let the oil change go beyond 3k miles, tops.
Old 03-29-2019, 10:19 AM   #9
6spdhyperblue
Drives: 2SS 1LE
Sounds like a step up to thicker oil would be a better solution if it’s getting too thin at any point during the interval. Not an oil expert tho
Just funny the trucks that share the same engine architecture don’t specify any oci modification for e85. That being they have to cover a 100k mike warranty on what could be used as a commercial work truck
Old 03-29-2019, 12:35 PM   #10
DorkMissile
DorkMissile's Avatar
Drives: DZ
Just keep an eye on the oil itself - it will turn dark a lot quicker on E85. I ran E85 in my sierra and it would usually be almost black by 5000miles. About 7000 on gas.
DorkMissile is offline   Reply With Quote
Old 03-29-2019, 12:41 PM   #11
6spdhyperblue
Drives: 2SS 1LE
When I run diesel it gets dark in 5 miles
Old 03-29-2019, 07:56 PM   #12
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Wait what?... Diesel in a Camaro?
Need4Camaro is offline   Reply With Quote
Old 03-30-2019, 01:33 PM   #13
1fujifilm
Drives: 2019 Mustang GT Convertible
Who in their right mind pays for a high performance vehicle and puts in low energy fuel that reduces horsepower? Maybe a Prius is in line?
Bear
1fujifilm is offline   Reply With Quote
Old 03-30-2019, 05:04 PM   #14
Chef-j
Drives: 2018 Camaro 1SS
Color has nothing to do oil life.
Many manufacturers recommended change engine oil more often with E85. Im guessing that because ethanol attracts water, which increases acid formation.
Id ignore OLM and go 3K ~4k in summer and 2k~3k in winter with synthetic motor oil (ofcourse depending on how you drive and how cold it gets.)
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
