Old 03-28-2019, 06:43 PM   #1
GreatWhiteLT
Drives: 2016 Silver Ice Metallic SS
TSP Headers
Question everyone, do the Texas speed headers with hi flow cats mount to the stock x pipe? Thanks again! I tried looking all over google but it only brings me to sales pages
GreatWhiteLT is offline   Reply With Quote
Old 03-28-2019, 08:03 PM   #2
Keloid
Drives: 2016 2SS
They "mount" in a way that you need to do some snipping on the stock x-pipe.
I'm yet to install mine, but when I called to check, I was told that with high flow cats, you're still required to cut and "mate".
1. Mark exhaust pipe 1 ¾ ” in front of 90° exhaust bend on left and right sides.
2. Remove cat flange connection to OEM exhaust. – 15mm
3. Modify OEM mid-pipes to mate TSP exhaust.
a. Cutting is required on the proper marked pipes.
4. Clean up cutting burrs on exhaust with file or dremel.
https://www.texas-speed.com/Images/i...2016camaro.pdf
Keloid is offline   Reply With Quote
Old 03-29-2019, 06:31 AM   #3
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
Keloid is correct, you need to follow the posted instructions. I have them on my car, be advised there are no O2 bungs in the catted connection pipes. If you want to have your downstream O2 sensors you can get the X pipe from TSP or make your own. This is what I have on my car, not sure if this is what part you are referring to.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 03-29-2019, 04:42 PM   #4
Redlinez
Shifts under load
Redlinez's Avatar
Boy I'm glad I read this. I knew nothing about the 02 sensor part. Thanks!!
22 Suzuki GSX-S 1000GT blue
Old 04-04-2019, 07:36 AM   #5
Anti_venomSS
Anti_venomSS's Avatar
Drives: '18 Camaro SS
I run 2' TSP Headers. I would highly recommend relocating the wiring harness next to the headers on the Passenger Side. Myself, and other people from the forum have melted this harness, causing fuses to blow and exterior lighting issues. Simply zip-tie the harness back and out of the way. Can provide you a photo if needed.
'18 Camaro SS; CIDs, Nitrous, Meth, 3100lbs
Built by High Performance Connection in HTX
Anti_venomSS is offline   Reply With Quote
Old 04-04-2019, 03:07 PM   #6
the chosen one
the chosen one's Avatar
Drives: 2017 Convertible 1SS A8
What's the downside to not having the downstream O2 sensors?
Kooks 1 7/8" LT catted headers, Katech Ported TB, SoCal ported IM, Green filter, Tuned by BCP, Borla S-Type axle-back, BMR springs, BMR front sway bar endlinks.
the chosen one is offline   Reply With Quote
Old 04-04-2019, 04:33 PM   #7
Baker
Baker's Avatar
Drives: 2010 camaro RS,2017 camaro 1Le
I would not mind that photo as I will be installing mine in the near future when they get back from being coated.
2017 camaro 1le
ROTO fab, Ported MSD, Ported 95mm tb, 2in TSP catless longtubes, flowmaster x-pipe, flowmaster American thunder npp, flex fuel,
Baker is offline   Reply With Quote
Old 04-09-2019, 06:33 AM   #8
AD17SS1LE
AD17SS1LE's Avatar
The wiring harness you that behind the coolant reservoir and zip tie out of the way. Unfortunately I don't have a pic from my install.
2017 Camaro SS 1LE
Pray ported TB/IM
Taylor plug wires
Elite X2 catch can
