03-28-2019, 02:54 PM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
2016-2018 Camaro ZL1 Style Carbon Fiber Hood
2016-2018 Camaro ZL1 Style Carbon Fiber Hood $1412.10
The ZL1 Camaro is an awesome performance machine. But there is always room for improvement. This Anderson Composite 2016-2018 Camaro Carbon Fiber ZL1 Style Hood looks like your factory hood but, it is made entirely out of carbon fiber. The carbon fiber construction of this hood will remove excess weight from the front of your car and with its enlarged opening this hood will remove more unwanted under hood heat to increase the power and performance of your ZL1. This hood also features carbon fiber bracing to add strength and keep weight down. Anderson Composites components are carefully hand-crafted using only the finest materials. Anderson Composites production team offers superior craftsmanship with many years of experience working with carbon fiber. Every component is constructed with a consistent weave pattern. Anderson Composites production processes allow exceptional carbon/resin ratio, creating high product stiffness that also leads to extra strength. For a stunning finish, our products are coated with a glossy clear coat that does not chip or flake. Anderson Composites meticulously inspect all of their components and stand firmly behind their products so that you can enjoy peace of mind with every genuine Anderson Composites product. *ZL1 STYLE WITH AGGRESSIVE "POWER BULGE" *CARBON FIBER "SKELETON" BONDED TO UNDERSIDE OF CARBON FIBER HOOD - REDUCED WEIGHT *MESH SCREEN IS REMOVABLE & PAINTABLE *MOUNTS WITH OE HARDWARE *REQUIRES HOOD PINS FOR SAFETY REASONS *STRONGLY RECOMMEND THE USE OF A HEAT SHIELD *ANDERSON COMPOSITES DOES NOT SUGGEST RE-INSTALLING GAS SHOCKS/DAMPERS/STRUTS https://www.rpidesigns.com/shop/item...on-fiber-hood/ |
10-29-2019, 01:51 PM | #2 |
11-08-2019, 06:15 AM | #3 |
Dyno Show Queen LOL
does this add any extra clearance to clear the eforce 2650
11-08-2019, 02:15 PM | #4 |
Hello,
Yes, it will add extra clearance for the supercharger. A guy is using this hood with a 2.9 Whipple. |
11-08-2019, 02:44 PM | #5 |
Dyno Show Queen LOL
Hows it fit on a zl1 vs an SS
11-11-2019, 02:07 PM | #6 |
