![]() Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
I have a 2018 Camaro 2LT which did not come with the wireless charger in the back. Does any one of you know if I can install the wireless charger in the back? I saw a listing in eBay that is selling the whole piece, but will I need to do any modifications before installing?
![]() Drives: 2017 Camaro SS 2ss Nightfall Gray Join Date: Aug 2018
Dont waste your time with it. Most phones wont fit in it unless they are really small
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels Roto fab Biggulp CAI Full paint correction with cquartz finest ceramic coating Whipple 2.9 ARH Long tube headers with High flow cats 1le sway bars F&R BMR Upper and lower trailing arms Hurst short throw shifter |
Thank you Al Oppenheiser!
Don't waste your $$$. It's one of those features that sounds cool and you think you want it, but once you have it you will never use it.
Wile a standard size Galaxy S9 will charge, you must a) have no case or a very slim case on the phone, and b) remove the rubber pad and set it at a goofy angle. And then the first corner you go around will have the phone fly off and land on the back seat or worse: fall down between the seats onto the floor. Besides, you cannot use Waze on Android Auto/Carplay thru the mylink without a wired connection. |
![]() ![]() Drives: Too many to list Join Date: Dec 2011
I upgraded mine to the wireless pad that works with the iPhone X. Unless you actually plan on using it then it’s pointless. Keep in mind the charging rate wirelessly is slower than the USB connection. I swapped pads just because I like for everything in my car to actually work, not because I plan on using it. But it does hold the iPhone X.
Sent from my iPhone using Tapatalk Pro |
| Tags |
| camaro6, wireless charger |
