Old 03-26-2019, 05:30 PM   #1
Liquidstone
Liquidstone's Avatar
Drives: 2018 ZL11LE
WEAPON-X.750 (Stage 2) [Camaro ZL1 gen 6, LT4]
Hey guys just wondering if anybody has this package and or something similar. My question is, are you guys have heat soak issues? Can this package handle a Track day? I have heard as soon as you upgrade pullies on factory blower that heat becomes an issue.
Side note: How is the Weapon x 800 package and heat soak. im curious because it comes with the heat exchangers.
Any input would be great. looking for reliable track power with no heat soak issues.
Liquidstone is offline   Reply With Quote
Old 03-26-2019, 08:04 PM   #2
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
I'd prolly call Ben at Weapon-X, I'm sure he would be well equipped to answer those questions.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 03-26-2019, 08:42 PM   #3
PROMETHEUS
PROMETHEUS's Avatar
Apples and Oranges - But I can tell you from experience with my corvette, the more you mod the car, the more heat issues you are creating, especially on the track. My previous 1LT corvette is NOT a ZL-1. GM has made some great cooling improvements on the Z06, which I suspect migrated over to the ZL-1. But nevertheless, you start moding the ZL-1, you are going to have to consider cooling issues as well. Ben at Weapon X is the person you need to engage in that discussion!
Old 03-26-2019, 09:13 PM   #4
2out2sea
Drives: 2018 hyper blue ZL1 1LE
https://www.camaro6.com/forums/showthread.php?t=542975
I think this might help
2out2sea is offline   Reply With Quote
Old 03-26-2019, 09:22 PM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
Looks like that package is mainly intake, ported TB, and pulley (with some extra stuff like plugs and Tstat).
I would imagine that the 2.3 upper wouldn’t create too much heat if any but I have no experience with that. If heat is a big issue, I wonder if an intake, ported SC with 103 TB, headers, and tune would be the better route for track use? Should make great power and less heat.
Markoz28 is offline   Reply With Quote
Old 03-26-2019, 09:59 PM   #6
Liquidstone
Drives: 2018 ZL11LE
The package does however include the Weapon X Heat exchangers also. Anyone with these exchangers without the chiller have heat soak issues. I totally get that they blowers once overdrive create shit ton of heat. Any input would be great. And thanks for all the support!
Old 03-27-2019, 06:48 AM   #7
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
All of the Weapon-x packages were tested and verified on my car.
If you go to the website about the chiller, you will see that with only the minor mods, we started seeing timing being pulled already due to the August weather and heatsoak.
I have the Full Weapon-X package on the stock blower, with the Weapon-X Heat Exchangers and the Boost Freeze Chiller. The car runs Fantastic and is cool as a cucumber all the time.
Actually, I am headed to Weapon-X today for the Polished Whipple and fuel system install...then I am done!
Give Ben a call, he will do you right!
Intimidator is offline   Reply With Quote
Old 03-27-2019, 10:22 AM   #8
Liquidstone
Drives: 2018 ZL11LE
Now how about with out the chiller BUT with the heat ex changers.
Old 03-27-2019, 11:10 AM   #9
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
As long as you ain't whipping the blower around, you'll be find on the heat. Do either upper or lower, don't do both and spin that blower. You can always run a meth kit if you want to keep those IAT's down. Remember it's the 1's and 2's and mani temps that kill timing, so if you can control all 3, you are fine.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 03-27-2019, 12:29 PM   #10
Liquidstone
Drives: 2018 ZL11LE
Thanks
Old 03-27-2019, 12:30 PM   #11
staples87
Drives: 2017 Camaro ZL1
Would running methanol at 50/50 mix before the throttle body be enough to keep the blower cool from heat soak to not pull timing, say even with an upgraded pulley?
staples87 is offline   Reply With Quote
Old 03-27-2019, 02:25 PM   #12
Intimidator
Upgrading the HX will suffice for your needs...but if you really start spinning the stock blower then you need a chiller!
I upgraded the HX just in case something happened to the Boost Freeze Chiller or the AC and I was away from home...that is my Safety net! lol
Old 03-27-2019, 02:54 PM   #13
staples87
I like your style! Although the extra fuel and cooling benefits you get from methanol will allow you to net more power.
Old 03-27-2019, 07:17 PM   #14
Intimidator
I'm not messing with any additive, e85, or ice...i can run 93 all day and 104 when I want to play.
My chiller has taken the water going into the blower down into the 20 degree range...in the summer it runs between 50 and 60 degrees.
