Old 03-25-2019, 10:01 AM   #1
Whatwarranty
Drives: 2016 camaro ss
Need a new block 😩
Well I finally got all my parts for my build picked block up from machine shop. Started assembling it got all my rings gapped and bearings clearances checked and assembled it. Wellllllllll got it all together and went to spin it and it would spin about 180 degrees. At that point I started taking everything apart. I found that cylinder one had a dent and crack in it from a timing cover bolt that was too long for that spot torque to 18ftlbs. So my block is trashed 😩. Does anyone happen to have one they can sell? Not wanting to waste money on a factory new block.
Whatwarranty is offline   Reply With Quote
Old 03-25-2019, 10:28 AM   #2
L78toLT1
L78toLT1's Avatar
can't you get it sleeved?
Baby Blue
Old 03-25-2019, 10:34 AM   #3
Whatwarranty
No it damaged the aluminum that they’d need when they resleeve.
Old 03-25-2019, 10:56 AM   #4
laynlo15
Drives: 2022 Lt1 A10
Man that really sucks for sure. Sorry to hear that.
Old 03-25-2019, 11:07 AM   #5
6spdhyperblue
Drives: 2SS 1LE
Prob better luck finding out out of a truck?
Old 03-25-2019, 11:32 AM   #6
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
First time hearing this, did you do new bolts for the timing cover?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 03-25-2019, 11:43 AM   #7
Whatwarranty
I’m sure I grabbed wrong one by accident. I’m not totally sure though because by the time I realized it I had already removed everything and bolts were in a pile. Just horrible luck. I literally posted pics of the motor with the caption “this went suspiciously smooth” then 30 minutes later found that it had a problem lol. (I put lol but it’s more of a crying man laugh) I even called the machine shop and he said he had never seen that and that he would have thought the bolt would strip before that. When I told it was only torqued to 18ftlbs he was even more shocked.
Old 03-27-2019, 07:12 AM   #8
GuywithL86
Drives: Black
I’ve been curious for awhile if this will work. I believe some of accessory connections to the block could be different.
Would be cool if all the camaro and vettes could source a high production truck motor
GuywithL86 is offline   Reply With Quote
Old 03-28-2019, 11:52 PM   #9
Jason 98 TA
Drives: Camaro
Call tsp and get a Resleeve.
Jason 98 TA is offline   Reply With Quote
Old 03-29-2019, 10:38 AM   #10
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
he is better off with a different block that way they don't have to tig the crack/hole shut. suspect issues later on if not repaired correctly.
besides a stock block is probably alot cheaper than sleeves & accompanying machine work
i do see that whatwarranty is close to texas-speed; so your right that's always a option..
whatwarranty you can order a new cylinder block from jegs and swap your water/oil plugs on over.
https://www.jegs.com/i/Chevrolet-Per...29617/10002/-1
hitmix300 is offline   Reply With Quote
