Old 03-23-2019, 09:40 AM   #1
Hilltopper
Drives: 2018 Camaro ZL1, 2017 Z06/Z07
LPE Injector/HPFP Install, Meth Delete Results
I picked up my SS 1LE Camaro from Vengeance Racing yesterday after they swapped out my LT4 Injectors and HPFP for the LPE K-DI Injectors and HPFP and uninstalled the Alky Meth Injection setup. I did not have any problems with the previous setup with Meth, but made a decision to make the setup a little less complicated, even if it meant leaving some power on the table, especially on the 93 Octane side of things. The only question I had was whether to use the LPE or FIC injectors. After several discussions with Ron at Vengeance, I decided to go with the full LPE setup. I am glad I did. Once everything was said and done, the tune updated (both on the dyno and several miles of driving on both E85 and 93), the new combo exceeded my expectations by a pretty good margin, especially on the 93 pump gas side of things. Final dyno numbers were 862 rwhp on E85 and 835 on 93 pump gas. The car has pretty good street manners for what it is.......that is, until I get into boost, then it's pretty unruly......but I can live with that. Ron and his crew have done an awesome job on this project every step of the way....I couldn't be happier!
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1
Hilltopper is offline   Reply With Quote
Old 03-24-2019, 05:00 PM   #2
ShizzySupra
Drives: 16' Camaro 2SS
So did it pick up more on 93 cause that would be odd. Curious to see what your IAT’s do off the dyno.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 03-24-2019, 07:51 PM   #3
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
You still running the single Zl1 Intank Pump?
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 03-25-2019, 07:10 AM   #4
David@Vengeance
Drives: 2017 Camaro SS 1LE
He has the DSX low-side system.
David@Vengeance is offline   Reply With Quote
Old 03-25-2019, 08:50 AM   #5
Hilltopper
Not sure of IAT's off the dyno, to be honest, as I just got the car back on Friday. I suspect the increase in power on the 93 pump gas dyno pull was due to there maybe being some residual amounts of E85 in the tank which helped it make a little more power. The E85 side of things picked up some horsepower over the meth setup, as well. There could be all kinds of explanations for the pickup in power. Tune changes, weather condition differences between January and March, ect. In any event, the last two dyno pulls were just to verify everything still looked good on both fuels after the driveability tune changes were completed.
