![]() Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Rev Match How To?
Sorry if this was covered somewhere else, but when I did a search there was a bunch of threads, which speaks briefly about rev matching.
Now I'm use to heel/toe, but it seems this is not necessary with the Rev Match...is this correct? Also, I see (in pics) there are paddles for the Rev match, so how does this work, do you pull the the paddle prior to shifting, or do you pull it once and it turns on Rev Match? Is the accelerator response quick enough to do a heel toe and not use those paddles? Sorry for all the questions, but Saturday seems like it's taking forever!! I know I need to just jump on the horse and ride, but my brain is wanting to know before I start riding...hehehe!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
You activate the Rev Match by pulling on a paddle once and the feature stays on until you deactivate it by pulling on a paddle again.
#3 | |
![]() ![]() Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
2017 1LE Hyper Blue
Thank you, that's what I wanted to know.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
In the instrument cluster there's a display that shows what gear you have selected, and normally it's a white digit 1 through 6, or R for reverse. When you engage rev match, that gear number display turns a shade of yellow/orange to let you know the rev match function is active.
When the car is started the feature is defaulted off, you have to flip either paddle to activate the system. It's either on or off. You don't have to click it every shift. It works on up shifts and down shifts.
'18 1SS 1LE Black, PDR
#6 | |
Good info to know about both up and down.
#7 |
![]() Drives: 19 SS 1LE Join Date: Nov 2018
#8 |
![]() Drives: 2018 SS 1LE Join Date: Aug 2018
I have never experienced rev match with an upshift, it just blips the the throttle when I downshift to stop the surging/jerking that occurs without it, making the downshift more smooth and annoying anyone around me when my Borla ATAKs scream out "AMERICA"
#9 |
On my wife’s ‘19 you get more pops and crackles if you manually blip the throttle versus using rev matching.
#10 | |
I discovered this while driving normal, found that if I applied throttle during a rev match up shift it was jerky, unlike a normal up shift. If the rev match is on you have to be off the throttle while shifting for a smooth up shift.
#11 | |
However I do not see why you would be pressing the throttle while changing gears (unless you are talking about no lift shifting, which is a whole other ball game) |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
accidently hitting on track and turning it off sucks lol wish it was a button instead of a paddle shifter style
#13 |
![]() Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
If I'm slow to let the clutch out on an upshift and have rev match on, I feel like it'll hold the RPM for a half second or more. Makes me think it is more of an actual rev match than a throttle blip.
For example 2nd gear, up to 5k, let off throttle, clutch in, shift to 3rd, hold clutch in, rpms drop to about 3K and hold for a count or two. let clutch out and enjoy smooth engagement. back on throttle and check rear view mirror for mustang in the dust. :-P |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
I get good throttle blips when in rev match mode on, take it out of gear and tap shifter all the way to teh left in neutral gate twice. I do this when coming up to a red light or whatever, it gives a nice double blip most of the time.
