![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
does a e85/93 tune require fuel pump module tune?
its a extra credit to turn the fuel pump module. Is it something I will need with just with e85 and other my mods in sig. asume if i do a cam it will.
No it's not required.
![]() Drives: 2016 2SS A8 Convertible Join Date: Aug 2010
but if you do..... and have npp exhaust you can then program and control the valves using your on console mode selector. KingLT1 helped me set mine up! Very knowledgeable guy.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
What areas could use work with E and lbo?
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I would do it because you can then adjust the max pressure and gain some flow.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
Does adjusting the fuel pump throw off trims and PE thus needed to readjust vve?
#7 | |
In your injector cal you will see flow vs pressure
#8 |
Gotcha thank you
#9 |
cool ill buy the extra credit. thanks
