#1 | |
![]() Drives: 2018 Camaro LT RS, 2015 Mazda 3 Join Date: Apr 2018
No automatic (touchless) car wash?
According to the manual, GM doesn’t recommend automatic car wash:
Thanks! |
![]() Drives: 13 Camaro SS Join Date: Oct 2012
Your car still has wheels...
Retired from Car mfrs....
Your car will be fine in a touchless wash. Find one that does not run the wheels in a track.
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I have a 1LT RS and have been through several touchless automatic car washes and never had a single issue
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
Touchless is fine but keep in mind, whatever wax, sealant or coating will be GONE! Touchless uses very strong detergents to clean the car.
ZL1::J-E-T-S JETS JETS JETS |
#7 |
Oh wow, didn't know they are so powerful. What do you suggest? I have a pressure washer at home, quality soap and everything, but since I live in Canada, is too cold to wash the car in the driveway... so until end of May, how do I wash it?
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Anytime above freezing you can do the rinseless wash method. https://www.autogeek.net/how-to-use-rinseless-wash.html
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
#9 |
Drives: 2019 Chevrolet Camaro 1LT 2.0T Join Date: Mar 2019
I feel very lucky to have Delta Sonic down here in Buffalo.
#10 | |
#11 | |
Sodium Tripolyphosphate:: used to clean concrete oil stains Sodium Metasilicate Pentahydrate Sodium metasilicates are non-flammable, non-explosive, and non-toxic. They are, however, alkaline materials and pose hazards to the skin and eyes. The physiological effects of contact range from causing irritation to causing chemical burns. Sodium metasilicate should be handled with care. Sodium Sesquicarbonate:: is 11 on the pH scale!! So ya, stuff is strong as hell.
#12 |
I use a touchless all the time. No wash, just rinse.
Then I go home and do a rinseless. See the instructions the way I do it in my signature below. |
#13 |
Thank you Al Oppenheiser!
Exactly. High pressure rinse to get the dirt and grit off... followed by a low pressure wash with agitation and a pH neutral soap to remove oils and grease.
Best of both worlds. |
#14 |
![]() Drives: 2017 2lt rs Join Date: May 2017
Go to a coin operated car wash,but don't use the brush.
