Old 03-20-2019, 01:02 PM   #1
wnyzl11le
wnyzl11le's Avatar
Drives: 2019 zl1 1le
Text Message Notification
I am sure it is something stupid I am missing but my 19 with the new infotainment system doesn't display my text messages like my 2018 truck does. I have gone into the Bluetooth settings on my phone and enabled notification but they don't show up. That is what I had to do with my truck to get it to show up. I was messing around with the phone settings in the infotainment system but all it would let me know is delete it. Has anyone figured this out?
2018 GMC Denali 6.2L
2019 Camaro ZL1 1LE 6 speed Riverside Blue 1LE NAV PDR. PPF entire car
wnyzl11le is offline   Reply With Quote
Old 03-22-2019, 01:21 AM   #2
Mize442
Mize442's Avatar
Drives: Current driver AMC emlin X 5ltr.
Don't you have to have it plugged in with the USB connection?
Mize442 is offline   Reply With Quote
Old 03-22-2019, 09:04 AM   #3
wnyzl11le
wnyzl11le's Avatar
If I want to use apple car play yes. I don't have to do that in my truck 2018 GMC. I am going to run over to the dealer once the weather breaks here
Old 08-25-2019, 08:21 AM   #4
kennyo
kennyo's Avatar
Drives: 2017 2SS Hyper Blue
Were you able to figure this out?
This is something that is beginning on my iphone
Mods-Corsa Extreme Axleback
kennyo is offline   Reply With Quote
Old 08-25-2019, 10:05 AM   #5
JD2018_ZL1
Drives: 2018 ZL1 Camaro
2019 Camaro has a newer system and they killed this feature a lot of guys complaining in the 19 Silverado forum about this as well
JD2018_ZL1 is offline   Reply With Quote
Old 08-25-2019, 02:01 PM   #6
Scraps0f
Drives: 2018 NGM ZL1
Wow this is stupid, on my '18 my phone doesn't always work with making calls via a wired connection, happens if I leave the phone plugged in and shut off and turn on the vehicle. But it always works over the wireless Bluetooth if I unplug it when this happens. For wired connection calls to work again I need to shut off the vehicle with the phone unplugged and then start the vehicle and reconnect the phone.
Scraps0f is offline   Reply With Quote
Old 08-25-2019, 02:55 PM   #7
You made me actually go out and test this one.
I use it all the time in my 18 Silverado and just assumed it worked in the Camaro especially since the new system is better in "almost" every way.
Old 08-25-2019, 07:17 PM   #8
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I understand the change, but they should make it an option.
I personally do not want my text messages broadcasted on my screen , especially when you have others in your car. I know in the upcoming iOS 13 update, there will be a Do Not Disturb option and a option to not send a notification when using Apple CarPlay.
For me it is a privacy thing.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 08-26-2019, 10:41 AM   #9
CamaroVille
Drives: 2018 Camaro 2SS M6
If you have an iPhone and want the texts to be sent the Infotainment system, do this, go to...
>Settings
>Bluetooth
>Click on the circled i to the right of "Chevrolet MyLink"
>Make sure that the "Show Notifications" is turned on.
You can check or change this on your phone anytime, you don't have to be near the car. I believe that this defaults to "Off".
When Show Notifications is on, you'll get an announcement that you have a text and if you're not moving you can choose "Read" and it will show you the text message. If you are moving, then you'll have to choose "Listen" for the system to read it to you. If you don't want anyone to hear it or see it, just ignore the announcement and it will go away.
Rick
2018 Camaro 2SS M6 NPP
HBM w/Black Metallic Rally Stripes
Built 6/21/18 -- Purchased 7/28/18
CamaroVille is offline   Reply With Quote
Old 08-26-2019, 01:14 PM   #10
wnyzl11le
wnyzl11le's Avatar
>Settings
>Bluetooth
Thanks but this only works for chevy head units before 19. The tech guy at the dealership called GM they told him the new head units no longer do that. I complained he said yep so is everyone else.
