![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Rear blew apart? Actually it’s the half shaft that came off.
Any one have experience with fixing the rear end cost wise. I guess I might as well upgrade gears and parts. I have not inspected it totally but it blew apart like a grenade, parts rain behind me on the road. I am currently killing an hour waiting for the flat top tow company.
Update: actually after inspecting the car in the light with wheels off it’s the half shaft that came off. Bolts let losse and sheared off.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 03-20-2019 at 01:20 PM. |
![]() ![]() ![]() ![]() Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
depends on which doc you go too...rear ends can be problematic...
A few have done that but its usually launching at the drag strip on drag radials. The Magnuson Camaro switched to a MW 9" ford. There are a lot of other costs involved so its a pretty expensive swap.
![]() Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
How did that happen? Could it have been the axle shaft bolts backing out?
![]() Drives: 2018 SS 1LE Join Date: Jun 2018
How the hell...
#6 | |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2010
Never Taco Bell... not even once...
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled 2004 Silverado single cab 4.8l v-8 2wd -- Traded 2018 Camaro SS 1LE -- Current DD |
#7 |
This happen while cruising or launching?
You have a lot of mods already. I would upgrade the rear. |
#8 |
It happened was cruising, maybe 30mph then I hammered it. Heard a loud nosie in rear, and then the sound of metal hitting undercarriage and falling on the road.
Have to still inspect the damage, towed it home last night in the dark. I could smell rear end fuild. Going to jack it up in a bit and take tires off to inspect the damage.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 03-20-2019 at 12:13 PM. |
#9 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Should be covered by warranty....right?
#10 |
It’s the passenger side half shaft that came off. What I heard was all the bolts flying off and the bang was when the shaft hit the undercarriage until it completely came off the diff. I have no idea if the diff is damaged.
I no there is a note out there about the bolts coming undone, the remedy from GM is longer bolts. WTF If it can happen to me it can happen to you. Check your bolts and get the longer ones from GM. Now the phone to the dealer.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#11 |
Did it wheel hop?
#12 |
![]() Drives: 2021 C8, 2022 Camaro 2SS Join Date: Jul 2015
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022 3400 1/25/2022 TPW 1/31 3800 2/15/2022 4300 2/19/2022 4B00 3/04/2022 4000 3/8/2022 Delivered 3/9/2022 ____________________________________ Order 6/01/2016 2017 2SS, NPP, 56R whls 3000 6/08/2016 3000 6/15/2016 TPW 7/18/2016 3400 7/7/2016 4200 7/25/2016 Delivered 7/28/2016 Sold May 2020 |
#13 |
No wheel hop, just lost power to the rear wheels and pulled over to the shoulder.
#14 | |
![]() Drives: 2016 Camaro 1SS Red Hot Join Date: Sep 2015
Red Hot 1SS
MRC NPP Black Bow Ties Black Metallic Rally Stripes Black Wheels With Red Outline TPW 12/14/15 1G1FE1R72G0133041 - 12/16 built 2/19/16 - It's mine!! Previous rides: 2011 Camaro LS 2010 Camaro SS 1988 Honda Civic Hatch B18C1 swap |
