![]() Drives: 2016 2ss Join Date: Jun 2016
Upgraded MAP sensor
I have a Whipple and do not have a map sensor that will register boost over 1 or so psi. I've been told not doesn't matter, I've also heard it does. Opinions or experience??
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Not sure what MAP sensor you have, but when i did my Whipple I installed an LT4 MAP sensor.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
#3 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
In the Case of the Whipple the LT4 IAT/MAP also known as a T-MAP, sensor and appropriate jumper harness are the best option. Your IAT gets moved from the MAF to the blower so your computer can track actual air intake temps at the intake port as well as extend your MAP harness to the back of the blower where the T-MAP is located. So the harness jumps the MAF connector and MAP connector and will plug in at the T-MAP. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
