Old 03-15-2019, 01:57 PM   #1
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
305 on a 19x10 front?
Just wondering if anyone has done a 305 (305/30 specifically) on a 19x10 front wheel? or if everyone has gone to a 19x10.5 or 19x11 for that?
If you've done a 19x10, any rubbing issues? offset?
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 03-15-2019, 04:37 PM   #2
hzycamaro
hzycamaro's Avatar
I'm currently running 305/30 in the front. The wheel is APEX PS-7 19x10.5 but I can't remember the offset. I do have camber plate installed and -2.2 front camber. No spacer needed.
hzycamaro is offline   Reply With Quote
Old 03-21-2019, 07:16 PM   #3
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
19x10.5" ET22 is the offset on your PS-7 wheel.
I don't recommend the use of a 305 wide tire mounted on a 10" wide wheel, however depending on the specs of the particular tire, it *could* work. It sounds like this would be a front wheel in a staggered setup, which in that case I would run a 10.5" wide at minimum, preferably 11".
We are producing 19x11" ET11 to be a front specific fitment on a 5th and 6th Gen Camaro. It is aggressive on non-ZL1 models and will require additional negative camber, but otherwise fits fantastic.
Here is a protoype setup on a 2018 ZL1 1LE. 19x11" ET11 front and 19x11" ET43 rear, all wrapped in 305/30-19 Bridgestone RE71R's.
- Cory
Apex Wheels is offline   Reply With Quote
Old 03-23-2019, 01:33 AM   #4
RideZX6R
RideZX6R's Avatar
- Cory
Like I said on fb messenger - when the 12in rears are available and maybe even some 18in diameter options... I'm in
'12 E93 M3
'25 911 (ordered)
Formers...
Old 03-23-2019, 09:26 AM   #5
kjchristopher
Drives: 911SC
Pretty much the only people who are doing this are limited in wheel width by their competition rules (SCCA street class autocross, for example). It works, but is not ideal. If there was a shorter 285, I’d pick that over the 305. But as there isn’t.... The RE71 has a stiff sidewall and has less downside than others when pinched.
If you’re not limited in wheel width, go wider for a 305.
kjchristopher is offline   Reply With Quote
