Old 03-13-2019, 08:27 PM   #1
JCurry2885
Drives: Black 2018 1SS Camaro M6
Normal Coolant Operating Temperature 2018 SS
What are you guys running when fully warmed up for your coolant temperatures? I'm running an obd2 p3 gauge and driving normal for awhile it runs right at 180 degrees. This seemed to cold to me. I left the car in the driveway idling for like 10 minutes and checked it and it was up to 205????
JCurry2885 is offline   Reply With Quote
Old 03-14-2019, 09:14 AM   #2
ctrlz
I have not hooked up scanner, but once warmed my 2SS routinely runs with the digital gauge pegged at the 11:00 hash mark, which I presume is around 200 deg.
If your car gets to 205 while idling then 180 while driving, your thermostat is likely sticking open a bit.
180 doesn't sound too low. But some cars may not enter closed loop mode in the 160 range. This will hurt fuel economy. I may be able to dig up the prerequisites for closed loop from the service manual.
Old 03-14-2019, 09:32 AM   #3
thrashergrant
thrashergrant's Avatar
Drives: 2018 Camaro SS 1LE
Mine also sits right at the 200º mark. Also in TX climate.
thrashergrant is offline   Reply With Quote
Old 03-14-2019, 10:22 AM   #4
enzia35
Drives: '16 Garnet Red 1SS
I don't think I've seen you around yet,
These cars run up to 210F when the fan kicks on.
'16 Camaro 1SS
'18 Miata GT
Old 03-14-2019, 10:39 AM   #5
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
These cars run normally from 180 to 210 which is where they are supposed to run. 180 is not too cold.
Old 03-14-2019, 11:43 AM   #6
ctrlz
My coolant temperature stays pegged at the 11:00 hash mark once the car is warmed up. That is how it has been from day 1. If it started to fluctuate around that mark, I would be worried about a sticking thermostat.
Now 180 may well be in GM's "acceptable" range, but I always start to worry when the coolant temperature fluctuates once the car has warmed.
The service manual does not specify the exact engine coolant temperature (ECT) for closed loop:
DESCRIPTION AND OPERATION > FUEL SYSTEM DESCRIPTION > RUN MODE
The run mode has 2 conditions called Open Loop and Closed Loop. When the engine is first started and
the engine speed is above a predetermined RPM, the system begins Open Loop operation. The ECM
ignores the signal from the heated oxygen sensor (HO2S). The ECM calculates the air/fuel ratio based
on inputs from the engine coolant temperature (ECT), manifold absolute pressure (MAP), mass air flow
(MAF), and throttle position sensors. The system stays in Open Loop until meeting the following
conditions:
The HO2S has varying voltage output, showing that the HO2S is hot enough to operate properly.
The ECT sensor is above a specified temperature.
A specific amount of time has elapsed after starting the engine.
Specific values for the above conditions exist for each different engine, and are stored in the electrically
erasable programmable read-only memory (EEPROM). The system begins Closed Loop operation after
reaching these values. In Closed Loop, the ECM calculates the air/fuel ratio, injector ON time, based
upon the signal from various sensors, but mainly from the HO2S. This allows the air/fuel ratio to stay
very close to 14.7:1.
Old 03-14-2019, 01:45 PM   #7
TJay74
Factory stat is a 190° if my memory is correct. 180°-205° is with in range. I have a custom thermostat housing on mine with the LS3 style 160° and mine stays around 160° to no more than 180° during the hotter summer months.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 03-14-2019, 02:26 PM   #8
JCurry2885
So 180 may not be out of line...the factory gauge is right around the 11 o'clock position like everyone says. I guess have the digital p3 gauge now just has me thinking more about it. Btw I'm about 40 min from college station like some of you above
Old 03-14-2019, 04:42 PM   #9
enzia35
Super weird!
'16 Camaro 1SS
'18 Miata GT
Old 01-27-2022, 08:27 PM   #10
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
Keep in mind if you run pure E85 the engine will run cooler.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 01-27-2022, 08:38 PM   #11
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
My 2020 SS runs right here fully warmed up, have never seen it any warmer...
Old 01-27-2022, 08:39 PM   #12
FarmerFran
FarmerFran's Avatar
That is where mine sat. I have pics somewhere
<Insert Cars You Own Here>
Old 01-27-2022, 08:46 PM   #13
2SS Capt
2SS Capt's Avatar
Mine has been there since day 1...
Old 01-27-2022, 09:02 PM   #14
FarmerFran
FarmerFran's Avatar
Well, ok - at day 360 for me it went a lot, lot higher.
