Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > ZL1 Parts
Old 03-11-2019, 02:34 PM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
Camaro ZL1 AWE Track Edition Cat-Back Quad Tips
2017-2018 Camaro SS And ZL1 AWE Track Edition Cat-Back Quad Tips Starting at 1295.00
Built of 304 Stainless steel this 2017-2018 Camaro ZL1 AWE Track Edition Cat-Back Quad Tips is a great sounding upgrade for your Camaro. This cat-back exhaust system is 3" system for maximum power and exhaust flow. Replacing your factory muffler with these AWE muffler free cat-back will save weight and give your Camaro a full race sound. These quad tip mufflers fit perfectly into the factory rear valance for a factory look. Without mufflers, your Camaro will be super loud and maybe too loud for you or your neighbors.
Features:
● Proudly engineered, designed, and manufactured in-house, in the USA
● No compromises: all muscle, zero drone
● Peak gains of 11 hp and 5 ft-lbs of torque, and max gains of 16 hp and 10 ft-lbs of torque to the crank
● Handcrafted from 3” U.S.-sourced CNC mandrel-bent .065” wall T304L stainless steel
● Precision-engineered X-pipe is standard in each catback configuration
● 4.5” double-walled tips in chrome silver or diamond black
● Less is more: clean, non-baffled, straight-through design maximizes performance
● Direct bolt-on system means factory-like simplicity
● No Check Engine Light -- Guaranteed
● Perfect Fitment -- Guaranteed
● Featuring the AWE Lifetime Exhaust Warranty
● The system does eliminate NPP function
https://www.rpidesigns.com/shop/item...ack-quad-tips/
RPI Designs is offline   Reply With Quote
Old 12-17-2019, 02:18 PM   #2
RPI Designs
Old 12-30-2020, 09:11 AM   #3
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPIDon is offline   Reply With Quote
