![]() Drives: 2016 SS 6 Spd Join Date: Jul 2009
2017-2019 Camaro ZL1 Painted Supercharger Cover
2017-2019 Camaro ZL1 Painted Supercharger Cover $759.99 With Code PHIL5 At Checkout
If you're looking for a way to really set your Camaro ZL1 apart from the crowd you will not be to find a better piece than this custom painted supercharger cover. This supercharger cover will turn years Z L1 Camaro into a show winning masterpiece. The 1st thing you see when you open the hood of your car is a supercharger cover why not make it the centerpiece of your under hood accessories. This is a factory GM part that we will paint to your specifications. You can select any factory GM Camaro paint color for the supercharger cover and the raised lettering in your choice of accent colors. This part will then be cleared with 3 coats of genuine DuPont clear for a deep shine that will last for years. This supercharger cover is custom painted to order may take additional time depending on GM stock. https://www.rpidesigns.com/shop/item...charger-cover/ ![]() |
Thank you for the orders!
https://www.rpidesigns.com/shop/item...charger-cover/ |
