Old 03-10-2019, 11:24 PM   #1
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Front brake upgrade for LS/LT?
Can someone tell me what the difference between these two brake upgrade kits is? And why one of them is $1200 and the other is $479?
https://wildhammermotorsports.com/ca...eneral-motors/
https://zzperformance.com/collection...ront-brake-kit
Thanks
protovack is offline   Reply With Quote
Old 03-11-2019, 01:08 AM   #2
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
I might go zzpl. Don’t think there’s any difference except the rotors.
RobertAvitia is offline   Reply With Quote
Old 03-11-2019, 06:40 PM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
the camaro branded ones are better rotors and comes with hoses + the Camaro branded calipers. the 499 kit is gm replacement parts except they are brembo only branded calipers. will you notice a difference No.
Old 03-11-2019, 09:28 PM   #4
protovack
If I went with the cheaper one, would I need to buy separate hoses?
Old 03-11-2019, 09:52 PM   #5
JCunningham
Drives: 2017 2SS M6
i dont know but is says it comes with everything needed to install them.
Old 03-27-2019, 08:35 AM   #6
sadboyleo
sadboyleo's Avatar
Drives: 2018 Camaro 1LT
You can easily get the 4 piston brakes for just over 450. I am talking about the performance one. Here is the link to it:
https://www.thatgmpartsguy.com/oem-p...3245470?c=az0x
And it has the performance logo if you actually care.
Last edited by sadboyleo; 03-27-2019 at 08:36 AM. Reason: adding some extra details.
sadboyleo is offline   Reply With Quote
Old 03-27-2019, 08:37 AM   #7
sadboyleo
sadboyleo's Avatar
If you can't find it on that website up there you can just look up the part number on google and find other re sellers. Don't pay more than 500 for those
Old 03-27-2019, 04:21 PM   #8
RobertAvitia
BYND GARAGE
This kit was discontinued
Old 04-10-2019, 11:52 AM   #9
ZZP_Tyler
ZZP_Tyler's Avatar
Drives: 2017 Camaro 2.0T RS
Our kit uses the "same" caliper, they use the same pad, ours just do not say Camaro on them. Personally I like the finish on ours better, nice gloss with some shimmer in it, but that's personal preference. I am just finishing up the install instructions for the Brembos currently and there is no need for different brake hoses; you can reuse the stock hoses.
ZZP_Tyler is offline   Reply With Quote
Old 04-10-2019, 01:32 PM   #10
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Yeah the Camaro SS ones have a crappy finish on them...none of us have been able to keep our's pristine with any mileage on them. The ZZP ones are obviously nicer...the plus side to the SS takeoffs is they are likely cheaper.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
