Old 03-09-2019, 07:29 PM   #1
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Need help with a wind related rattle
Brand new 2019 LT 2.0T
At speeds of 50-90mph, there is a wind related rattle coming from somewhere near the right (and sometimes left) mirror area. It is not linked to RPM. Going over bumps does not cause it, and its the same on smooth or rough roads. The loudness of the rattle increases as speed and windnoise increase. It's kind of subtle, but extremely annoying. It sounds like a plastic part impacting a body panel. It is kind of random, almost as if something is flapping in the wind. It's not rotational and has nothing to do with wheel spinning. Very hard to tell if the sound is inside or outside of the car.
The sounds almost goes away if I get behind a tall vehicle in their wind shadow.
If I get in front of that vehicle, the sound comes back in full force, which is why I'm sure its wind related. I'm just not sure HOW.
thanks for any help
protovack is offline   Reply With Quote
Old 03-09-2019, 09:01 PM   #2
The "good old" mirror noise perhaps?
https://www.camaro6.com/forums/showthread.php?t=460078
Old 03-09-2019, 10:03 PM   #3
protovack
I'm honestly not sure if its that noise or not. I don't have a whistle. What I do have, is a rattle above 60mph that is very clearly related to wind/air. It gets super noticeable if I get up to 70mph. 80mph it is loudest, and above 90 it actually goes away. To be clear, it is not wind noise itself. It is definitely a rattle, just one that seems to be linked to air speed.
Old 03-15-2019, 11:21 PM   #4
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Check your air dams/undercladdings. Flapping as speed increases, doesn't exist with high speed.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-16-2019, 01:03 PM   #5
Karl Carson
SHRFT
Drives: 2017 2SS vert 50 anniversary
Door noise
I had a noise like that. There are two plastic plugs on the bottom lower edge of the door. One was loose, I glued it, noise is gone.
Even though all the mosquitoes are roasting in HELL, I still don't like winter.
Karl Carson is offline   Reply With Quote
Old 03-16-2019, 09:52 PM   #6
protovack
thanks for those replies, I'm going to check the undercladding and the lower part of the door. I also have an appointment at dealer in a couple days in case it is the mirror or something else I can't do. Will update when I figure it out.
Old 07-17-2019, 03:25 PM   #7
protovack
well, I finally figured out what was making this noise.
It was my air dams. I took them off to experiment with gas mileage, and the turbulent wind noise around the mirrors disappeared.
