Old 03-09-2019, 12:29 PM   #1
Calubi
Drives: 2017 1SS 1LE
Replacing broken lock pin in ignition coil harness?
Okay, how screwed am I?
I managed to break off one of the red locking pins in the plug that connects an ignition coil to the wiring harness. These are the (apparently very fragile) plastic pins that need to be pulled up before you can pull the connector off the ignition coil. I pulled up on the pin head, except it broke off instead of just popping up!
Luckily, the connector is stuck ON the ignition coil so the car still runs fine. I'm hoping a tiny screwdriver will let me remove the remains of the pin that is keeping the connector locked, but I'd like to get this fixed. Any idea if the red pin itself can be replaced without needing a whole new connector? Or if a whole new connector is needed, is there a way to change it out without requiring a new wiring harness?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 03-09-2019, 09:06 PM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
They are just a "fail safe". Not needed. Don't sweat it. I broke 2 of mine. No problems. Getting the red piece out was kind of a pain. Small screwdriver and tweezers iirc is what I used
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 03-10-2019, 10:12 AM   #3
Calubi
Thanks for the info! I'm mainly concerned with the connectors working themselves loose without the lock pins, but if others are not having issues then that's good!
Old 03-10-2019, 11:54 AM   #4
6spdhyperblue
Drives: 2SS 1LE
They seem like they are replaceable. Maybe a tech or someone can let us know what the dealers are doin and how to order
Old 03-13-2019, 07:34 PM   #5
647
Drives: 2017 Camaro 1SS M6 Whipple SC
I broke one of mine about 15 months ago, I went 12 months without any issue. Forgot about it until I installed the 2-step, will probably forget about it again until I have to take it off for something else.
647 is offline   Reply With Quote
Old 03-13-2019, 08:01 PM   #6
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Same thing here, I have a two step and just ended up putting some electrical tape around the broken one.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-14-2019, 01:21 AM   #7
Dubchitts
Dubchitts's Avatar
I even broke one off the 2 step side. Those things are way too brittle. But as long as they don't get stuck to where they won't release, it's not a big deal
"Spitfire" 427ci
Old 03-14-2019, 02:28 PM   #8
Calubi
Mine is stuck in a position where it's preventing removal of the connector. I don't have a pressing need to remove the coil pack at the moment, luckily, but I plan on trying to get the last bit of red plastic out of there sometime in case I do need to remove it in the future.
Old 03-14-2019, 03:16 PM   #9
6spdhyperblue
Drives: 2SS 1LE
Can u fish it out with a pick?
Old 03-14-2019, 03:23 PM   #10
Dubchitts
Dubchitts's Avatar
It might help to unbolt the coil and hold it upside down. Might make the red piece easier to grab and fish out
"Spitfire" 427ci
Old 03-16-2019, 08:54 AM   #11
Caspeyy
Caspeyy's Avatar
Drives: 2014 Camaro RS
I broke off the back rear one, aka the one thats a pain in the ass. It wouldnt release as well. In the end i had to break the black clip on it to pull it out. Luckily i was installing a 2 step and when i plugged the broken one in the dummy coil of the 2step i just wrapped it with electrical tape. No problem yet atleast
Caspeyy is offline   Reply With Quote
Old 03-17-2019, 01:52 AM   #12
Buckscamaro
Buckscamaro's Avatar
Drives: 2016 ss camaro
i have a few broken ones too. No issues yet and we basically hot lap my car at the track.
You tube channel:
G's footage
https://youtu.be/VCnanR8qsNg
Instagram: boogieman_racing
Buckscamaro is offline   Reply With Quote
