#1 | |
![]() Drives: 2023 ZL1 1LE Join Date: May 2018
Girodisc Brake Rotors...
I did a search and don't see that anyone is running these. According to the video, you lose some swept area (Not good), but you also lose close to 5lbs of rotating mass. Has anyone run this set up?
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
Seeing how the rotor reached the outer edge of the brake pad, I'm not sure how you could lose swept area, but if they save 5 pounds each, that could certainly be a benefit.
Who Needs to KNOW?
Loosing mass on rotors is usually bad idea. Mass = thermal capacity, less is not better.
Of course, that all depends on your usage pattern, track car def wants that mass. Daily, or autocross - perhaps not.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Roscoe has these with Garage Therapy in NC but hasn't run them on track yet.
![]() Drives: 2018 ZL1 1LE Join Date: Nov 2017
From what I remember from Ken's post, the ring is the same overall size however the hat is larger causing the pad shape to be different.
2018 ZL1 1LE
#6 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I had the same design Girodisc 2 piece rotors and ST-43s F/R on my Evo X and they were an amazing upgrade. With the stock (4 piston front and 2 piston rear) Evo Brembos, I had no problem braking deep from very high speeds, running neck and neck with my friend in his 991 GT3RS, with zero overheat. And we were often 1-2 in the advanced group at our HPDE at ACS Roval, a very high speed track that tests your brakes. |
#7 |
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
Honestly I'd like the ability to run the 1405 series pads (C7 Z06). Lots of options and easier to get. Dumping some weight is a plus. Nice stuff!
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
