Old 03-03-2019, 07:50 PM   #1
CamaroRed_SS
CamaroRed_SS
CamaroRed_SS's Avatar
Drives: Red Hot 2016 Camaro 1SS
2016 Camaro SS Heater acting up!
I’ve had my 6th gen Camaro for 2 years already and now when I’m parked my heater doesn’t blow hot air and it’s terrible! Especially with the cold weather right now, it works when I’m moving but when I come to a stop it gets cold so I just turn it off until I get moving again. Any ideas on what it could be & how to fix it, I’m currently in line at Dairy Queen and it’s 20 degrees outside and I’m freezing in the car with the heater off!
CamaroRed_SS is offline   Reply With Quote
Old 03-03-2019, 08:01 PM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
This might be a stupid question but does your outside temperature reading seem to be correct. My sensor went out in the Caddy once and the HVAC had a terrible time.
dpevans is offline   Reply With Quote
Old 03-03-2019, 08:21 PM   #3
CamaroRed_SS
CamaroRed_SS
Ye’sir it reads the right temp outside, in the mornings I remote start it twice so by the time I get in to head to work it’s warm inside but now it doesn’t help, at least the engine is warmed up but in the car it doesn’t warm up at all idling.
Old 03-03-2019, 08:28 PM   #4
weatherman71
Drives: 2019 Camaro 2SS
check coolant level..... thats a sign of coolant being low
weatherman71 is offline   Reply With Quote
Old 03-03-2019, 08:31 PM   #5
CamaroRed_SS
CamaroRed_SS
Really? I actually have a bottle of coolant in my trunk so I can go fill it up right quick and see if it helps any.
Old 03-03-2019, 09:49 PM   #6
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
I’ll save you a trip to dealer. “It’s normal”. Just like everything else that goes wrong in the car.
Wolvie70 is offline   Reply With Quote
Old 03-03-2019, 11:14 PM   #7
CamaroRed_SS
CamaroRed_SS
Right, dealers don’t do their jobs like they should!
Old 03-03-2019, 11:23 PM   #8
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Its not the coolant level, if it was, you would be getting cold air regardless if you were parked or moving. Check your temp gauge while you're parked. Is the engine up to operating temperatures or is it a bit low? does it drop off when you're not moving?
It sounds more like your thermostat is stuck open. When its stuck open, coolant cannot remain in the motor long enough to heat up, its constantly pumping and cooling and not allowing the motor to reach operating temperature. When you're driving, there is enough heat generated by the motor to warm it up even in full circulation, but not the case when you're parked.
Need4Camaro is offline   Reply With Quote
Old 03-04-2019, 08:37 AM   #9
CamaroRed_SS
CamaroRed_SS
I’m going to take my car by a local mechanic to see what the deal with it, that makes sense on why it only works when driving. I do a lot of driving so with cold weather everyday here in west Texas so that’s why I need it to stay warm
Old 03-04-2019, 04:55 PM   #10
thomaswatk
Drives: red ss convertible
I didn't know it got cold in west Texas.
thomaswatk is offline   Reply With Quote
