Old 03-02-2019, 06:55 PM   #1
Nato301
Nato301's Avatar
Drives: 2018 2ss/1LE performance
Vibration @ 65-70mph
So I took my 2018 2ss to the dealer yesterday due to vibration. It felt like the whole front of the car is vibrating and I’m freaking out, cause I just got the car almost two weeks ago. I mean it’s still relatively new because it only has 2800 miles on it “now”. So I’m like maybe the road isn’t smooth enough and I kept shifting lanes thinking it’s just the road but it wasn’t, So the dealership I go. I explained the situation (to the service center advisor) and they insist that they keep the car overnight. They gave me a loaner “2019 Lt Rs camaro, crush color” so I can get to work. So I’m like okay I’ll drive this “Cheeto”. 4 hours later I called them to give me a follow up, the guy told me they had experienced the vibration. They explained that Mobil 1 has some old chemical fluid for the transmission that’s not compatible with some cars and unfortunately mine was not. Hmmmm, so they said they’ll change it with “Mobil 1 up to date fluid” and that should resolve the issue. Also he mentioned, they’ll change out and flush all the fluids. Now I hope he didn’t mean “flush transmission fluid” cause that can screw up my transmission right? I mean the car is new. I’m freaking out, anyone else experienced this?
Nato301 is offline   Reply With Quote
Old 03-02-2019, 07:12 PM   #2
mgwarlock
Nightfall Gray Blackout
mgwarlock's Avatar
Magic oil they are claiming
There is a thread already that you can check... a lot of owners has the same problem.
Good luck!
mgwarlock is offline   Reply With Quote
Old 03-02-2019, 09:16 PM   #3
Nato301
Nato301's Avatar
Thanks man, I’ll see if I can find it
Old 03-02-2019, 10:32 PM   #4
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
Look up "A8" "Transmission Shudder" "Class Action" and you should find all the threads associated with this.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 03-03-2019, 07:24 AM   #5
Nato301
Nato301's Avatar
Your awesome man, thank you
