![]() Drives: '18 Black SS 1LE; '01 Corvette Z06 Join Date: Nov 2018
Modifying stock seats to accept 5/6 point harness?
Hey guys,
I just picked up my SS 1LE in October and she's currently "in the barn" waiting for the snow to melt and track season to begin. I'm considering options on harnesses and mounting points. Because my much shorter wife will be co-driving the car, the club I run with doesn't allow 4-point harnesses unless they're make/model specific from Schroth, and I don't really want to go back down the "track car" path, I'm considering modifying my stock 1LE seats to accept the anti-sub belt so I can place the anchor under the seat. Sitting on the belt run from behind the seat is not an acceptable option for me so let's not debate that option. I also want to keep the stock seats in the car since it will also be street driven. I have a friend who has done this modification to his '17 GS with the competition seats, and the upholstery shop did a fantastic job making it look like it was designed that way. I'm curious if anyone has done this to their stock Recaros and if you have a picture I could show the upholstery shop as well as part numbers for the harness guides. Thanks! Jim |
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
Most nationally sanctioned organizations ban modifying seats for harness pass throughs. I wouldn't even consider it even if it wasn't banned. I also would not buy a car with modified seats...
#4 | |
However, even if your "local track club" allows the use of modified seats, you're likely pigeon-holed to only running with that club... and only so long as they allow modified seats. PCA/NASA/CCA/etc does not allow modified seats. I've seen many Corvettes with modified seats like you describe. |
#5 | |
![]() Seriously I do understand where you're coming from. I used to be the guy enforcing the "PCA Minimum Standards" for my PCA region. ![]() I'm also intimately familiar with Club Race rules and tech standards for PCA as a former tech inspector. I've also read the Schroth warning in every one of their product listings: " A seat that was not originally designed for use with a racing restraint should never be modified to accept a sub strap." The PCA "Minimum Standard" does not specifically prohibit modified seats, (although some regions have added stricter language which is their prerogative) and the modified C7 Corvette "competition" seats is exactly where the idea came from, since some genius made seats with shoulder pass-throughs but didn't include one for the sub-strap, similar to the Camaro engineers building a track car with seats that are not conducive to using harnesses. Several of my friends have modified their C7s. Having said all of this, I'm actually leaning toward trying to convince my replacement that he should grant me an exception for the Schroth Profi II ASM 4-point system. So you've talked me out of it. Happy??
![]() Drives: 2015 Camaro 1SS Join Date: Dec 2017
There's a company called Garage Therapy NC that make a harness guide for 6thgen seats.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
As to GM engineers...well, not much difference in terms of seat design between them and Pcars, Bimmers and other marques imo. A good idea imo, as harness without a proper roll bar/cage is an interesting "safety" concept all in itself. And given your background i am sure you are intimately aware of its details. Anyhow, congrats on the purchase and enjoy the car. It is a track beast and a pleasure to drive! Cheers! |
#8 |
Garage Therapy also makes a sub belt bracket for stock seats, but you wind up sitting on the sub belt(s) which I'm not sure is a good idea. Opinions on this solution?
#9 | |
#10 | |
Unlike in a Vette where one sits on top of shallow butt bolsters (as the seat is much narrower due to lack of space) the Camaro seats offer superior support there and the bolsters are much higher and actually do the job. Ditto side back support bolsters, which offer a comfy position to lean into - in the corners. In any case, see what you think. All the best and cheers! |
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Although that routing (over wrapping it over the front of the seat cushion) does allow proper anti-sub holding, I wounder if it is acceptable? |
#12 | |
I'm going to see how the stock belts work before deciding on harnesses. |
#13 | |
#14 | |
