Old 03-01-2019, 06:42 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Anyone try the DSC controller for mag ride?
Anyone try it yet?
Old 03-02-2019, 10:42 AM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Lots of threads about the device if you search. I haven’t looked in the last year, but I recall there being some perceived issues.....some hardware related, some software/tune related if the car got light of crests on track.
ninetres is offline   Reply With Quote
Old 03-02-2019, 11:13 AM   #3
Badmojo
aka BeastZL1
Badmojo's Avatar
They've upgraded the controller several times and some of the early issues were heat related due to the temperature on the trunk floor of the Camaro and the Amp that sits on top of it. They now recommend putting down Dynamat or something similar under it. Porsche guys swear by it and there is a Youtube video that shows a nearly 2 second lap improvement on a ZL1.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 03-02-2019, 11:17 AM   #4
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
I came from the Corvette Forum before trading my Z06 and getting a ZL1.
On the Corvette is was a Love - Hate story depending on cars use.
Please instruct on how to better search.
I tried just "DSC Controller" and got a total of 7 ,,, 4 didn't actually have info about usage , just the DSC was somewhere in the thread.
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
Indyblue98 is offline   Reply With Quote
Old 03-02-2019, 11:38 AM   #5
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
What is wrong with the factory calibrations that you would want something like this?
gotswap is offline   Reply With Quote
Old 03-02-2019, 12:18 PM   #6
ninetres
ninetres's Avatar
I can relate that sometimes searching doesn’t always produce the threads you are looking for.....but it sounds like you found at least 3 with useful info.
I just specifically recall ample discussion and feedback from users posted in this forum over the past couple years. Best of luck!
Old 03-02-2019, 12:48 PM   #7
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
THIS!!!
GM has been using MRC since the C5 Corvette, they have the programming and algorithms down.
DSC, is just something different, not better. They soften up the ride in places to make it "seem" like the ride quality is better, but then ask the system to make bigger delta changes when you amp up your driving style.
From most of the comments I have seen about it, there is one common theme... it creates a floaty feel and instability in certain situations because they relax the damping in normal driving.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 03-02-2019, 01:09 PM   #8
Bow Tie Fanatic
Drives: 2018 Mosaic Black Metallic ZL1 A10
I’m buddies with the OP and he knows I have a new gen DSC controller. I had it the last time we were at VIR and I think it made a difference but was in a run group that didn’t allow me much of any clear track. I still managed a decent lap but will know much better about the DSC controllers benefits when we go back in 3 weeks. If I run the lap I want to run on the stock tires then I will post the lap on the forum and probably be ranting about the product. We’ll see.
Bow Tie Fanatic is offline   Reply With Quote
Old 03-02-2019, 02:15 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
The early results were from the prototype in Luke's ZL1 A10 at Summit Point. Thanks for any info from the Camaro platform. If you have been to any of the DSC lectures, you would understand where GM left some room for improvement. Nothing wrong with GM's calibration; however, DSC has made adjustments to the GM parameters which allow quicker reactions of the MRC shocks. Vette guys love this controller. I just wanted to know if anyone recently had tried this in a Camaro. Fanatic will continue to prove this controller's worth.
Old 03-02-2019, 02:39 PM   #10
TRZ06
TRZ06's Avatar
In order to make it react quicker you would need faster processing power no?
Did they change the chipset?
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 03-02-2019, 03:01 PM   #11
Badmojo
aka BeastZL1
Badmojo's Avatar
The factory system changes the shock dampening based on wheel movement and not what the car is actually doing. The DSC controller uses G-forces, braking, and throttle data to more accurately use the factory hardware.
2019 Camaro ZL1 1LE
Old 03-02-2019, 03:03 PM   #12
Stephen12ZL1
Drives: '21 ZLE A10
Supposedly "real time" in the DSC...I'm not a computer engineer so I can't comment on the chipset. They have a FAQ on their site to address any of these technical questions. http://www.dscsport.com
Old 03-02-2019, 03:43 PM   #13
Badmojo
aka BeastZL1
Badmojo's Avatar
2019 Camaro ZL1 1LE
Old 03-02-2019, 05:56 PM   #14
TRZ06
TRZ06's Avatar
Originally Posted by Badmojo View Post
That is not a good measure. any number of differences can change lap times. Even within the same session, lap times can vary.
It is only something you would be able to tell while driving them, back to back in person. Both on the track AND the street. The street will be more telling since you are subject to a lot more difference road conditions and imperfections.
On the street is where a suspension is really tested.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
