Old 02-27-2019, 10:11 AM   #1
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Proper burnout procedure
I have seen a few posts where the A8 seems to have been damaged and even exploded during a burn out. I'm looking to see what people are doing to get their tires warmed up. I have the SJM line lock so I'm just looking for how you are using the transmission. Manual mode second gear hold around 3-4k rpm? Or just leave it in auto and mash it? Looking forward to your comments.
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 02-27-2019, 11:05 AM   #2
grampa_ss
grampa_ss's Avatar
At the strip, I push it over into manual mode. Powerbrake it to break the tires loose and rev it between 4-5k. Hold it for at least 10 secs, let off the brake..keep on the gas a little and then let off. Since I don't launch from a high RPM, the tires are sticky enough for me to leave at an idle. I think some guys get it into 2nd gear and get the tires spinning up to 50MPH.
Old 02-27-2019, 11:12 AM   #3
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
The one that exploded during a burn out in the water box was well over the rated HP limit rated for that transmission.
dmcmahan60 is offline   Reply With Quote
Old 02-27-2019, 11:13 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
start in the gear you want to do the burnout in via manual mode and don't let it shift.
Old 02-27-2019, 08:17 PM   #5
Brianw36
SNSTRSS
Brianw36's Avatar
Old 04-01-2020, 02:59 AM   #6
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Is it better to be on 1st or 2nd gear in order to do a proper burnout? Also all nanies (TC, SC) should be off, right?
Old 04-01-2020, 12:01 PM   #7
Umbriel
Drives: 2016 Camaro SS
Most people do the burnout in second.
Umbriel is offline   Reply With Quote
Old 04-01-2020, 01:04 PM   #8
grampa_ss
grampa_ss's Avatar
I do my burnouts in 2nd gear now too. And with the M/T ET street SS, you only need about a 4 sec burnout.
