02-24-2019, 07:06 PM | #1 |
Drives: 2018 1SS 1LE Join Date: Dec 2012
Front higher then rear?
Did eibach springs and find that the front sits higher then the back. Anyone else run into this issue ?
02-24-2019, 08:24 PM | #2 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
It sits like that from the factory too. If you change the rake of a car, you change the handling characteristics and usually not in a good way.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
02-25-2019, 06:54 AM | #3 | ||
Drives: 2018 SS Join Date: Jun 2018
The wheel well cutouts on the body are larger in the front, but the chassis sits slightly lower in the front. |
02-25-2019, 09:58 AM | #4 | |
02-25-2019, 03:00 PM | #5 |
Have you had an alignment done yet? Did you tighten everything while hanging on the rack after installation? If so that could be one reason. I've seen a 1/2" change by letting the car settle before everything is torqued to spec and that should be done on the alignment rack.
