![]() ![]() Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
Trying to figure out what gauge(s) to run
So I picked up an ECS Novi 1500 kit, waiting to install it in the next 2 weeks then up to ECS for them to tune it. I'm not sure if they're going install a 3 bar MAP sensor so I'm holding off on picking up a boost gauge until then(I assume if they wire in a 3 bar I can get boost readings from the OBD2 port correct?).
If I decide to go analog boost gauge what do you guys recommend that will properly fit in the pod? I'll most likely go with the single pod that clips onto the vent on the dash, was it hard running all of the wiring through? If I decide to go with a second gauge what would you guys do? If the tune is dead on do I really need to run a wide band? I did a search and found some older threads, looking for some recent ideas. Thanks guys!
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. Last edited by FrostySS; 02-24-2019 at 06:39 PM. |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
wideband
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
Aem 30-0334 with vent pod and torque pro app on your phone with a pro clip holder.
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
AEM 30-0334 wideband. it come with a passthru OBD2 connection.
dual pod choices are: https://zzperformance.com/collection...uge-pillar-pod or https://www.phastekperformance.com/D...ro-campod4.htm or you can run the single pod and then one of those gauges that mounts in the vent like the NGauge or P3 gauge.
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
I run an Aeroforce and an AEM wideband.
2018 ZL1…Many mods to come
