Old 02-23-2019, 09:25 AM   #1
ADM PERFORMANCE
Drives: Anything I want
2017-2019 ZL1 Expansion tanks back in stock
This kit allows you to have a reservoir on your 2017 -2018 zl1 so that you can fill and check the system periodically. It is complete with mounting bracket,bottle,hoses and hose clamps.Uses all OEM Connections and clamps to the supercharger.
We have a few of the Expansion tanks for the ZL1 boxed and ready for shipment as of 2-23-19. The last time we announced them we sold all in one day so don't wait very long. We are sitting on 10 ready to go with new updated instructions and also much easier install than the first generation.
Install note - The first generation of these you had to remove the Intake system from the car to access the intercooler pump inlet, this made for beat up hands since it is a bit tight to get to. The latest version only requires you to disconnect the outlet of the supercharger coolant line, remove the fill barb fitting from the factory hose and install our hose that leads to the bottom of our expansion tank. 5 min at most. The other line on our expansion tank plugs in to the supercharger utilizing factory connection barb. PLEASE NOTE YOU MUST REUSE THE CLIP FROM YOUR OLD BARB on the new 90 degree quick connect.
Here is the link - https://lsa-conversion-store.myshopi...sivoir-upgrade
ADM PERFORMANCE is offline   Reply With Quote
Old 02-23-2019, 09:47 AM   #2
PROMETHEUS
PROMETHEUS's Avatar
Will this work on the MY 19?
Old 02-23-2019, 01:07 PM   #3
ADM PERFORMANCE
Will work on 2019
Yes it will work on the 2019 ZL1
Old 02-23-2019, 05:02 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
please address everyones warranty concerns...I have it and feel it should have been a factory item. Nice piece!
Old 02-23-2019, 07:07 PM   #5
PROMETHEUS
PROMETHEUS's Avatar
Hey Stephen, how much more coolant does that thing hold! Cant really get a sense of size from pics. I am coming from a Corvette that had a lot of overheating issues on the track and don't want to have those issues again! It looks like they have improved the installation process since you got yours. I read your thread on it!
Old 02-23-2019, 07:58 PM   #6
It's not really the volume it adds but the ability to actually fill the system.
GM learned from the vette and added extra coolers so overheat hasn't been an issue.
Old 02-23-2019, 08:45 PM   #7
Stephen12ZL1
Drives: '21 ZLE A10
The volume isn't as important as the fact this item self bleeds the inherent air pocket formation that plagues the LT4 intercooler circuit. Street driving wouldn't cause any of these problems as much as road course scenarios. No matter what, this setup is a great add and looks factory installed. Most techs would question if this was a factory setup installed by GM. The overall cooling is amazing in the Camaro ZL1 and has no overheating issues with regard to the engine coolant temperature, oil temperature, or transmission fluid. I have run this car in 95+ heat for 30min sessions at VIR, and it has not let me down. The above system is the "new and improved" version that actually fits better and holds more fluid. I've installed both and the new one is top notch.
Old 02-24-2019, 11:49 AM   #8
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Is this a 'messy' install or do the factory connections seal when you pull the OEM tubes off?
Old 02-24-2019, 11:58 AM   #9
Stephen12ZL1
Drives: '21 ZLE A10
only slightly messy...no way around dropping a few ounces of Dexcool when disconnecting the factory hoses from the intercooler pump (the messiest) and the upper manifold. Once this happens, the mess is over. Get some 50/50 Dexcool from your local parts store to prepare for the install.
Old 02-24-2019, 12:32 PM   #10
kwav8r
Flyin NOE
Thanks for the info!
Old 02-24-2019, 01:26 PM   #11
PROMETHEUS
PROMETHEUS's Avatar
Hey Stephen, you going to VIR in March?
Old 02-24-2019, 01:53 PM   #12
Stephen12ZL1
Drives: '21 ZLE A10
Yes, signed up for Trackdaze! https://www.trackdaze.com Hope to see anyone from the forum there. I have a garage beside another foum member. He is a '18 ZL1 A10. My car # is 88.
Old 02-24-2019, 08:11 PM   #13
PROMETHEUS
PROMETHEUS's Avatar
Maybe I could have you help me install that expansion tank, while I am there!
I have a 19 Shadow Grey M6.
Old 02-24-2019, 08:51 PM   #14
Stephen12ZL1
Drives: '21 ZLE A10
no problem...bring it and I will install it at the VIR garage. If you don't have a Rotofab (don't buy one) get a Green panel air filter (#7299) and we will slap that in your stock air box (preferable). See you there and leave everything else stock besides brake fluid and maybe brake pads. If you plan to run more events, get a set of track pads as the stock pad material will be imbedded in the rotors and swapping to track pads after this event will cause brake shudder and chatter.
