![]() Drives: 2010 camaro Join Date: Dec 2017
Attention Camaro 1le track rats.
How many track miles have you put on your Camaro 1le?
How many miles have you put on your 1le camaro? Any issues whatever? Any aftermarket modifications done to your powertrain because of tracking? What has come loose if any (not talking lug nuts here) lol ? How long has the stock clutch last you? Is the transmission and gears fine after 50k miles? Any issues? please report. Car has been out for two years now with good amount of people tracking them. Want to get in a 1le for road course within the next year. Just want too know what has broken or needs to be replaced. |
Because Racecar!
13k miles on car
not sure about track miles... but a little over 20 hours on track. finally getting new tires for the up coming track season no issues (almost. see "what came loose") no aftermarket mods. I was impressed with the OE tires so i bought the same one for the next set. During my first track outing by the end of the day the front end was clanking. Sway bar link nut was loose. simply re torque and move on. trans shows no signs of an issue (though i'm at 13k miles on the car) My only issue is that it is a little tight for head room with a helmet on. If you are over 6' tall, test fit one while wearing your helmet. |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
15k miles in two years. About 15 track days. Don't know the track miles. Bone stock except for Moreno camber plates (I went too far with them though). No issues ever. Change oil after two track weekends or 4000 miles whichever comes first. Diff oil after 5 track weekends or annually. Trans fluid once. On third set of OE tires. On 5th set of OE brake pads and second set of front rotors.
The car has been absolutely bulletproof. Tire and brake consumables are pretty expensive though. I stopped dailying the car so it could stay fresher for the track. Went with an ND Miata to daily. I will note that cosmetically the car is a bit vulnerable. Rock chips on the front of course, but also in front of the rear tires. Don't expect the paint to stay perfect if you track the car or drive on the street with these crazy OE tires. The steering wheel and shifter suede also wore out pretty fast but I haven't bothered to replace them yet. They seem to wear faster on the track when I use gloves but the suede grip is excellent. So I guess they work as intended if you consider them wear items.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Camaro ZL1 1LE (Red Hot) - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
![]() ![]() Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Fluids, tires, brakes, repeat.
2017 1LE Hyper Blue
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I'm just shy of 10k miles on the car being essentially stock (aside from brake fluid, alignment, and oil catch can), 6 total track days. Aside from keeping up with fluids/consumables, only issues I've had are the front stab bar links loosening and the wheel clicking noise issue. I put blue loctite on stab bar link nuts and a very light coating of anti-seize on the wheel/rotor interface and neither of these issues have come back.
I absolutely recommend a 1LE for road course use. So far the car seems extremely well suited for the track and doesn't show signs of needing anything major to keep it going.
2017 SS 1LE.
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
I'd wager I probably have the most track miles of a SS 1LE, around ~8k on track miles. 20k total miles. Most of my miles are driving to/from the track.
Thus far -many sets of tires -many sets of brake pads -I'm about to mount my 4th set of front rotors and my 2nd set of rear rotors -I change the engine oil about every 3-4 events, I've never seen my "oil life %" go belove 50% (this guage is appaently based upon usage). Usually 2k miles -I change the transmission fluid about 2x a year, and I change the diff fluid with almost every oil change. The one fluid that ALWAYS looks terrible, is the diff fluid. I use my car very hard, so I change it regularly (plus its very easy to change on a lift) -Only mechanical issue I've had that was unforseen was an aux radiator got punctured driving on the highway around VIR... not on track -My rear wheel bearing are making noise right now, so I'll be replacing those before my next event. I'm not complaning one bit about these wearing out, I've used my car very hard for many track miles on sticky street tires and many sets of Non-DOT Pirelli slicks. Wheel bearings are a wear item, plus they're only $73 per side. I talked more than a few people into the SS 1LE, I'm a lifelong Porsche enthusiast that couldn't resist a $42k car that can run with GT3's and GT4's from the factory, and that doesn't overheat on track. One of my good friends who was a Porsche Cayman owner drove my car @ VIR on street tires, he got out of my car and said... "well the Cayman is for sale". 6 months later, he bought a SS 1LE. |
#7 | |
#8 |
![]() Drives: 17 SW 1LE Join Date: Jun 2017
Best car ive ever owned. Tires, brake pads, fluids, repeat...
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Best car ever. Incredible track package bone stock plus alignment and fluids - that's it.
2 seasons close to 40 days with zero issues. Consumables and maintenance about the same as Provoste. Stock tires which rival more expensive Cup2s and RE71Rs last about 6-7 days. As all others it seems. EDIT: RS4s last a good 12 days based on Provoste's experience. What to check: 1) some early cars had an electrical harness rubbing against AC belt. Easy to check and tie it off if necessary 2) several cars (incl mine) had F end links get loose. Once tightened they stayed tight. 3) Factory alignment can be all over the place best to set it to track asap. GM warranty covers track duty in case something goes boom. Thats it
#10 |
![]() Drives: '17 SS 1LE Join Date: Jun 2017
I echo the same that everyone else mentioned. ~9.5k miles on mine now and ~16-20 full track days on the car. No mods, only track alignment and pads/fluid. I continue to use OEM tires; they provide an awesome performance/$ ratio. Regular maintenance and I also do diff fluid at the start of every season. Haven't done trans fluid yet, but I probably should...
The only issue I've had per se is that I've cooked the rubber boots in the front calipers but I'm leaving it alone for now. Probably too much heat from the race pads - this wasn't an issue with OEM pads. KNSBrakes sells a brake duct kit now that looks nice. I think I'm going to pick that up and install for the warmer months this season. Like TrackClub mentioned - keep an eye on rear axle bolts and endlinks (there are TSBs for both of these); check those as part of your regular tech. I've never had either loosen. |
#11 |
![]() Drives: 2017 1LE Join Date: Jul 2016
39k miles total here, used to be my daily driver and also has been through 8 track days including 2 at road america. So far only have had two issues: 1) ac belt was rubbing wiring harness, fixed by dealer (as mentioned above by TrackClub) 2) Oil pan was very slowly leaking oil last summer. Caught it and had entire pan replaced by dealer with no cost to me. Bone stock minus the borla cat back and knock on wood zero other issues. Still cant believe how awesome the 1LE is for the money and how much confidence it inspires in a novice driver like myself.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
#12 |
15 track days last year and no issues except needs more driver mods. Follow track prep guide and good to go.
#13 |
1LE Convert
Yeah, the suede has fully worn off the wheel where the thumb rests are. I do clean it every couple of months.
#14 |
![]() Drives: 1LE Join Date: Dec 2016
39k daily driven miles and ~5 track days. I run snow tires in the winter and so far have replaced the stock tires with the same thing a couple of times. It has a Mishimoto catch can which is the only modification. I've changed the rear diff fluid, given it a track alignment, in addition to running the oil specifically for track days. The car is due for front brake pads but the backs have more than 50% left.
Issues: Front sway bar end links needed to be tightened after the first track day - I'll buy the TSB locknuts this spring Lost an exhaust valve and the camshaft (it was 6 weeks after my last track day so unrelated. My fairly large dealership said they had never seen this before and they know it sees track time.) The best and fastest track car I've owned in more than 15 years of track work. I'm faster in this car because it feels stable, safe and predictable. On my short track I believe I'm 1/2 second faster than the highest level of Race PTM. I'm not getting any trophies so PTM is less stressful than running all off. Another benefit of PTM is it keeps my 19 year old son safe while still allowing him to get a little sideways;} |
