![]() Drives: 2017 1ss 1le Join Date: Feb 2018
Quick brake fluid question
Looking to hit the track soon. I am aware of all the preps that are a must. Probably just do 3 or so track days a year. Prices are double in Florida compared to track days in California. Anyways I'll prob do either motul 600 or 660. I understand the initial flush. But why does everyone recommend bleeding before every track day? Also how often would I need to do complete flush with the motul? Thanks. Proud new owner.
![]() Drives: 2018 1SS 1LE Join Date: May 2018
I use Motul 660 and Hawk DTC60 pads. I fully bled the system (all the bleed valves on all the wheels and starting at the farthest caliper) at the beginning of the season. I usually bleed a little out of the fronts (which get significantly hotter than the rear) before every event. I remove the wheels to measure brake pad thickness so I’m in there anyway. This habit come from the myriad of Car I tracked with small brakes. It may well be superstition now as the brakes on the 1LE are pretty stout. I will note that during my first couple of events I’ve encountered a “long pedal” which indicated the fluid in the caliper exceeded its max temp and boiled which produces small air bubbles in the caliper. A quick bleed typically fixes it. I’ve come off track and seen rotor temps over 600F and caliper temps over 500 even during cool weather.
I’ll probably fully bleed every couple of months. The reason is the brake fluid absorbs moisture that reduces it’s boiling point. Nearly all of that absorption occurs in the reservoir which is vented to air. In my case each time I bleed, contaminated fluid gets closer to the caliper. I want to fully bleed before it reaches them. And finally, because anything orth doing is worth overdoing, I bought the KBS Brake duct kit. I’ll install it as the weather gets warmer... Last edited by x_jarhead; 02-20-2019 at 01:40 PM. |
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
I don’t bleed my brakes before every event, I average a bleed prolly every 2 events, just a quick foot bleed to get fresh fluid to the calipers. BTW, RBF660 has no real advantage over RBF600, yes it has a little higher dry boiling point, but more importantly RBF 600 has a higher wet boiling point (401 vs 421) and is cheaper. I use SRF (518 wet boiling point).
![]() Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Castrol SRF matches RB600 for dry boiling point, but still has a very high wet boiling of 518F compared to 399F for RB600. Consequently it can be left in much longer between bleeds. Yes it costs more up front, but you'll save money and time in the long run. If you're only doing 3 events, so long as they're within 6 months IIRC, you probably won't need to rebleed with Castrol.
Nigel |
#5 | |
![]() ![]() Drives: A few Join Date: Oct 2017
Granted if you actually DO boil the fluid then you have to at least bleed but I don't see most doing that with a 1LE.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
#6 | ||
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have the motul 600 but my local trackrat shop told me to upgrade to the castrol srf stuff its pretty much all they use
#8 |
So with the more expensive srf u basically just do a quick bleed 1 time a year? How often do u do a full flush? And when u do a little bleed u will still need a new un opened bottle correct?
#9 |
As per the product data sheet, you should at most go 18 months between full flushes. But if you are tracking the car, a full flush at least annualy would be wise. No need to do a partial (quick) bleed. One bottle is enough for a flush.
#10 | |
I do yearly flushes. Financially I used to go through 15-20 bucks of fluid every 2 events, now I do one $70 bottle or whatever it sells for an Amazon once a year which can be 6-12 events pretty easily.
-Dave
#11 |
![]() Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Just wondering if any of you use the Motive Pressure Brake Bleeder when flushing your fluids?
This would be a pushing action on the fluid. Or do you use a pull vacuum type bleeder instead?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
#12 | |
I flushed everything with gallons of water and tried again. But it did it again. This time I noticed it right away though. I thought maybe the thin gasket was the wrong choice, so I tried the thicker gasket. This time it at least started leaking during the dry test. But I still couldn’t figure out why. From every angle I could see, the cap looked to be on properly. I finally resorted to using a mirror to see the underside of the cap. It turned out that one of the tabs on the cap was going around the outside of the tab on the master cylinder, instead of under it. Since it wasn’t going over top of the tab on the MC, it still looked like it was on, and felt like it was on, but it couldn’t hold pressure for any length of time. I still like the concept of the Power Bleeder, but I have a hard time trusting it now. The last time I used it, I just left it empty and checked the MC level from time to time to be sure I didn't run it dry. It's more of a hassle that way, but at least it avoids the potential mess if the cap doesn't hold. Nigel |
#13 |
![]() Drives: 2017 1LE Join Date: Jul 2016
I've got the motive bleeder. The first time I used it I had the same issue Whitespeed mentioned above and made a complete mess. Once I got the right gasket in and the cap seated properly the motive worked very well. I've used it twice since then and had no complaints. I will admit for $68 (plus I bring my own fluid) my local dealer will do it for me. I got lazy this spring and just had them do it lol.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
#14 |
![]() Drives: 2020 Camaro LT1 Join Date: Mar 2020
Hey guys, I'm new to the road course. I've recently began tracking my Camaro and found out that I definitely need to switch to some high temp fluid. It seems like everyone here recommends the Castrol SRF. How much do I need to complete the job?
Also, it sounds like switching the pads out is very common. Is there a particular brand or type I should be using? Car is my daily driver, but I really enjoyed that and autocrossing it so I'd like to go on a somewhat regular basis. Thanks in advance! |
