Old 02-18-2019, 01:43 AM   #1
Chewie_0341
Drives: 2019 Mosaic Black Camaro SS
Has anyone switched out the 2019 reverse lights for LEDs?
Just wondering if anyone has done this, and the difficult of it. Really want to switch mine out, but i haven’t found any. Wondering if the Diode Dynamic LEDs for 16-18 will work? Any info would be appreciated. Thank you.
Chewie_0341 is offline   Reply With Quote
Old 02-25-2019, 10:31 AM   #2
bigwormgraphix
Drives: 1991 Z28, 2015 SS & 2017 SS
We have done testing on the 2019s, unfortunately GM made this mod a lot more difficult. You have to remove the rear bumper to install the resistor harness and it will need a different harness than what 2016-18 Camaros use. If you install bulbs without the harness the reverse lights will stay on when you unlock your doors. So far your the first person to ask about it. Removing the rear bumper isn't as difficult as it sounds actually. If there is enough interest we can make a harness to work for 2019 Camaros.
bigwormgraphix is offline   Reply With Quote
Old 03-07-2019, 02:18 AM   #3
AshenBatmobile
Drives: 2019 SS
I'm interested.
AshenBatmobile is offline   Reply With Quote
Old 03-07-2019, 08:42 AM   #4
bigwormgraphix
Originally Posted by AshenBatmobile View Post
I'm interested.
I'll be sure to keep you updated. Currently were working on a new web site, so looks like at least May/June before they are ready to sell.
Old 03-07-2019, 09:40 AM   #5
AshenBatmobile
Drives: 2019 SS
Thanks!
Old 03-07-2019, 07:35 PM   #6
Jeremeymt
Jeremeymt's Avatar
Drives: 2018 Hot Wheels 2LT
GM still didn’t make the reverse lights led???
Jeremeymt is offline   Reply With Quote
Old 03-07-2019, 07:41 PM   #7
bigwormgraphix
Correct, 2019 uses the same bulb as 2016-18
Old 03-08-2019, 10:42 PM   #8
AshenBatmobile
Drives: 2019 SS
What LED bulb would you recommend using for the reverse light?
Old 03-09-2019, 12:21 AM   #9
Jeremeymt
Jeremeymt's Avatar
Old 03-09-2019, 11:10 AM   #10
MemBluff23
Drives: 19 Camaro SS
https://www.camaro6.com/forums/showthread.php?t=545702
MemBluff23 is offline   Reply With Quote
Old 03-09-2019, 12:14 PM   #11
bigwormgraphix
It's still a 7440 bulb, just reacts different than the 2016-18 Camaros due to different tail light wiring.
Old 03-09-2019, 12:19 PM   #12
bigwormgraphix
Gen5diy should have a harness out soon that will allow led bulbs to work correctly. After that any 7440 size led bulb will work, we recommend the Diode Dynamics XP80 (brightest bulb available and we have had zero failures/problems).https://www.bigwormgraphix.com/2016-...rse-bulbs.html
Old 03-09-2019, 08:53 PM   #13
Jeremeymt
Jeremeymt's Avatar
I just don’t understand why they don’t go full led all the way around.
Old 03-26-2019, 05:48 PM   #14
Luis19SS
Luis19SS's Avatar
Drives: 2019 SS A10
Any updates on this?
Black 2019 SS A10, MBRP Exhuast, Soler performance Ported Throttlebody, Cold Air Inductions CAI, BMR equipped, Stance SFO7 on nitto NT555G2 tires, Limited Edition White Racing Seats, ZL1 1LE Splitter, Carbon Sideskirts, Gorilla Splitters areo kit, Next Gen Speed Diffuser, JWmotorsports LED side markers
Luis19SS is offline   Reply With Quote
