![]() Drives: 1967 Camaro, 2017 HBM ZL1 Join Date: Dec 2016
12v accessory fuse location
I’ve searched this forum 50 different ways and can’t seem to find the answer, but does anyone know the location (position number) of the fuse that controls the covered 12v accessory port behind the shifter? The fuse in my compressor failed to blow and started melting the tip of the plug, now I get no voltage to the 12v port, hopefully the fuse blew but I’ve checked everything that would be logically relevant to it. Only thing close I’ve seen is the CB2 large circuit breaker type fuse in the trunk block but it’s not visibly popped and when I hit it with a multimeter I get a completed circuit.
![]() Drives: 2016 Camaro RS Join Date: May 2016
The fuse locations ive came across in my 1lt is under the hood, in the trunk wheel well area, and in the trunk behind the carpet on driver side rear. (Above the wheel i guess you could say) Never look for that fuse specifically but thats all the places ive seen fuses. Not a direct answer but hope that helps.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
![]() ![]() ![]() Drives: 2016 2SS, SW Join Date: Oct 2009
CB2 in trunk is Retained Accessory Power. I'd say that's it.
