Old 02-13-2019, 08:09 PM   #1
Tkinch96
Drives: Chevy Camaro SS 1LE
Uniden R3 cutting power
I have a Uniden R3 with the Gen5Diy harness attached to a blend mount. Most of the time when I lose traction and spin the tires power will be cut to my radar and will turn off and not turn back on. I have experienced this with a mirror tap harness and the current plug and play one from gen5diy now. Has anyone experienced this and found a fix?
Tkinch96 is offline   Reply With Quote
Old 02-13-2019, 08:30 PM   #2
ChangerOfWays
ChangerOfWays's Avatar
Drives: 2017 2LT RS
I have experienced this as well on the same setup (R3 /w gen5diy harness and blendmount) - thought it might just be a bad harness or poor connection, but haven't investigated it further. Two or three times it has also randomly cut out while just driving straight at lower speeds (no traction loss). Would be interested to hear of a possible reason or fix.
ChangerOfWays is offline   Reply With Quote
Old 02-13-2019, 08:34 PM   #3
Tkinch96
Haven't had it cut in normal driving (yet) but it seems to only happen with Uniden radars. Have posted the same question in a FB group and people with v1's and 360's don't seem to have the problem. But i can shake the Uniden like crazy and it won't turn off. So I don't think it's the radar. It's very confusing
Old 02-15-2019, 09:38 AM   #4
stook2001
Drives: 99 M3, 04 STi, 16 2SS
How interesting, I have this issue as well and assumed it was a loose connection. I am not using a harness, rather I am using the little pins that slide into the oem harness connectors. By the way, I also get a low battery warning on the detector sometimes when I startup the car. I never had either issue while using the OEM lighter power thing.
stook2001 is offline   Reply With Quote
Old 02-15-2019, 11:39 AM   #5
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
I have the R3 and Gen5DIY plug n play harness. I dont have a blend mount, just use the factory suction cup mount positioned to the left of the mirror. I have not had this issue in over a year.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 02-15-2019, 11:48 AM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Sounds like the Uniden R3 is pulling to many amps, and is sending the BCM into safety mode, OP can you call me at work ask for Ofer, we may have a new harness for your car, any one that has our harness with the Uniden R3 get a hold of me and will see if we can get it right with you, ones more ask for me and let me know that you have a Uniden R3.
2SSRS@Gen5diy is offline   Reply With Quote
Old 02-16-2019, 08:48 AM   #7
Tkinch96
Got a new harness coming from Gen5, will update this post and the company when I have the new one installed and tested. Thanks Gen5!!
Old 02-17-2019, 08:51 AM   #8
speedup
speedup's Avatar
Drives: 2017 2SS Convertible
TY sir, I have the same setup as you (R3, and gen5 harness) very interested in this..
@Gen5DIY - can we exchange our cables for the revised/newer one if this fixes the issue?
2017 2SS, Hyper Blue, 8sp, NPP, MRC
speedup is offline   Reply With Quote
Old 02-19-2019, 01:47 PM   #9
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
I to am having the same problem. When traction control comes on the R will shut off. BUT if I disable traction control I do not have any problems with the R3 turning off. Weird
gmw0181 is offline   Reply With Quote
Old 02-21-2019, 12:04 PM   #10
2SSRS@Gen5diy
So our new harness did not fix the problem, but i like to try and figure this out, is any one willing to help by sending us there unit? PM or call us.
Old 02-21-2019, 12:14 PM   #11
2SSRS@Gen5diy
ones we find the fix that is the plan.
Old 02-21-2019, 12:34 PM   #12
Move'n Up
Move'n Up's Avatar
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500
I'm confident that you'll figure it out.
Build Date 8/1/2016 1,109 out of 5,982| Club F1FTY
Move'n Up is offline   Reply With Quote
Old 02-21-2019, 01:34 PM   #13
Kaizer_911
Kaizer_911's Avatar
Following this thread.
I too have a Uniden R3, Gen5DIY Harness, and Blendmount in my 6th gen. I have not had this issue, yet. But I’ve also had very little seat time in the Camaro lately due to weather, work, and health. But I have the Gen5DIY harness in my truck and have yet to have the OPs issues happen there.
Guess swapping cables soon.
6000 - 07/08/16 | Club F1FTY
Old 02-21-2019, 06:57 PM   #14
Kaizer_911
Kaizer_911's Avatar
I can confirm issue this issue does NOT happen in my truck, a 2014 GMC Sierra, with the following setup: Uniden R3, Gen5DIY Harness, Blendmount.
On the way home from work today found an empty lot and made traction control and stabilitrack come on. Not hard in wet weather lol. Unit stayed on, no issues and no lights on dash other than TSC and Stabilitrack activating.
So it seems like this is a Camaro specific issue. But I haven’t tried in my Camaro yet.
Hope this info helps Ofer. And looking forward to a solution and if need to swap my Camaro cable it’s easy to remove it luckily lol.
power loss, radar, uniden
