Old 02-12-2019, 12:28 PM   #1
Chemist
Chemist's Avatar
Drives: HyperBlue 2SS 6M NPP MRC Nav
Exhaust exiting one side at startup
Is this normal? Shouldn't the exhaust come out of both sides during a cold startup?
2016 HyperBlue 2SS 6M NPP MRC Nav
Chemist is offline   Reply With Quote
Old 02-12-2019, 12:31 PM   #2
Umbriel
Drives: 2016 Camaro SS
If you put your hand on both sides of the exhaust does one feel completely different than the other?
Umbriel is offline   Reply With Quote
Old 02-12-2019, 01:19 PM   #3
RyanR623
Drives: SS A8, NPP, Red Hot
Huh, never seen that before. Mine definitely comes out both. I wonder if one of your AFM valves is stuck.
RyanR623 is offline   Reply With Quote
Old 02-12-2019, 02:36 PM   #4
Chemist
Chemist's Avatar
Nothing comes out of the driver's side exhaust on startup. This is only in Touring mode. The dealer, of course, says there is nothing wrong.
Old 02-12-2019, 02:41 PM   #5
Umbriel
I'd find a different dealer because that it not how it should work. It is strange that it only does it in Touring mode though.
Old 02-12-2019, 03:00 PM   #6
oOKhanhOo
Drives: 2018 SS 1LE
Did you look into the driver side exhaust to see if the valve is stuck?
oOKhanhOo is offline   Reply With Quote
Old 02-12-2019, 04:02 PM   #7
Mullet_Machine
Drives: SRT4, 2ss
If your in touring mode in that vid, the car sounds a little louder than it should be. It sounds like the npp valve on the driver side is working, but on the passenger side its not (stuck open).
Mullet_Machine is offline   Reply With Quote
Old 02-13-2019, 10:08 AM   #8
Paro
Drives: 2016 Hyper Blue 2SS A8
Outside pipes meant valve open (loud). Inside pipes means valves closed (tour), at low idle. It would seem if you are in tour mode and low idle both inside pipes should have flow.
Paro is offline   Reply With Quote
