![]() ![]() Drives: 2002 z28, 2023 Zl1 Join Date: Sep 2012
2019s have camera in spoiler , swap possible?
I'm looking into the 2019 but really don't like the stanchion spoiler and would like to swap it out , have any vendors addressed the fact that thers now a camera in there ?
![]() Drives: 2017 Camaro SS Join Date: Apr 2014
Just add an aftermarket camera above the license plate portion like it was in the 6th gen if you remove the factory spoiler. What's the main concern you're having?
The 19s have 2 cameras , one in the spoiler and one by the license plate so you can’t move the one from the spoiler to the other spot
Well... why you need two? They do both record your rear, right? You can just retrofit the spoiler one above the license plate as well right next to the camera if you still need both installed.
#5 | |
![]() Drives: 2017 2LT RS Join Date: Oct 2017
To the OP - as far as I know, none of the aftermarket vendors have offered a solution to this, so I think you would be on your own to retrofit the spoiler camera into your new addition. I think this would be easier for some, such as the blade spoilers - less likely with a ZL1 style spoiler. |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Gen5DIY is working on a kit it will require the 19 Spoiler if I recall.
**FIFTY HBM 2SS VERT** |
#7 |
I'm sure if you give it another few more months, all the newer kits for 2019 models will come out on the market.
#8 |
We will be bring out the one for the 2019 cars starting this week, and we will mod the one for the GM 3 pc spoiler to start.
#9 |
#10 |
![]() Drives: 2019 Camaro ZL1 Join Date: May 2017
Bump because looking for update on 2019 spoiler options (for those with camera in spoiler)..
1987 Camaro V6 1988 Camaro IROC Z 1993 Camaro Z28 1999 Camaro SS 2017 Camaro SS |
#11 |
I'm hearing the camera was moved into the shark fin antenna for 2020. You might even want to do that instead.
https://www.camaro6.com/forums/showp...&postcount=146
#12 | |
#13 | |
Any other vendors working on a 2019 "camera spoiler" alternative? Really not a fan of the stock spoiler on my ZL1.
#14 |
![]() Drives: 2019 stn stl gry zl1 convertible Join Date: Aug 2019
Bump for info on this dilemma. Us Convertible guys will need a solution that does not involve the sharkfin camera as it would be partially or wholly obscured by either the spoiler or the stanchion.
I have a couple of spoilers on the way and an after market camera to see if i can fit it. Otherwise I'll have to cut the factory Camera out of the stock spoiler and fit it in whichever one I decide to run. Will report on the outcome |
