Old 02-08-2019, 10:55 PM   #1
Drsagacity
Drsagacity's Avatar
Differences 2015 LT4 SC and 2019 LT4 SC
Just wondering if anyone can really outline the differences in the older LT4 Supercharger and the new 2019 model? I know the newer models have a taller lid, but what else is different?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 02-09-2019, 02:33 AM   #2
SpaceCadet
Drives: '99 Vette, '02 SVT Focus
the Tall Lid LT4's came with angled intercooler core bricks to 'improve' (fix Z06 overheating) cooling performance, the cores are same thickness as original LT4 cores. nothing else on supercharger casting is different.
2019 HP/Tq. rating has stayed the same, so I presume (not seeing one in person) nothing on engine/supercharger has changed, doubtful since that would cost GM $$$$$$
SpaceCadet is offline   Reply With Quote
Old 02-09-2019, 04:37 AM   #3
Drsagacity
Drsagacity's Avatar
Can you simply change the lid from the old supercharger to the new supercharger so that you can use the shorter lid?
TBD performance
Old 02-09-2019, 03:13 PM   #4
SpaceCadet
No, the angled intercoolers are to 'tall' for short lid. What are your goals?
Maybe these dimensions could help you? and or others?
https://wegnerautomotive.com/assets/...ers-Sep-18.PDF
Old 02-09-2019, 09:57 PM   #5
Drsagacity
Drsagacity's Avatar
On my other LT1 car I have a good friend getting rid of his LT4 blower, pulling off a 2019 Camaro. Because of my hood, I really need the lower profile lid. I have everything I need, but basically...the new setup is going to run about 600whp on that ride and be done...it’s officially my daily driver.
TBD performance
Old 02-09-2019, 11:03 PM   #6
oldman
Drives: SS 6 speed of course
well that hood is super cool. It is worth it.
Old 02-10-2019, 01:06 AM   #7
Drsagacity
Drsagacity's Avatar
It’s for my Vette, not my Camaro. My Camaro is just about perfect as is. We will finish the tune and get into the 800’s next summer so we can make a few passes.
The Vette will stay around 600whp as it’s my daily driver.
TBD performance
Old 02-10-2019, 05:38 PM   #8
SpaceCadet
The Vette guys says it hits the hood? Looks like it will clear without a hood insulator. But that is directly to cylinder head, are you planning to use LT1 to LT4 adapter plates so you dont have to drill heads?
Old 02-10-2019, 06:17 PM   #9
Drsagacity
Drsagacity's Avatar
Yes. I am using the adapter plates for the install. I was really just trying to figure out the differences that cause the lid to change. . .especially since the car never changed HP ratings, etc.
TBD performance
Old 02-10-2019, 06:28 PM   #10
SpaceCadet
find someone, CTSV? that wants to swap you intercoolers/lid?
Old 02-10-2019, 08:07 PM   #11
Drsagacity
Drsagacity's Avatar
To make the new LT4 blower work, you are saying we just swap to smaller intercoolers and the shorter lid?
TBD performance
Old 02-10-2019, 08:07 PM   #12
toohighpsi
Drives: 2015 C7 Z06 M7
I don't think you can swap lid/intercoolers from the earlier to the later version, I believe it is a different SC housing. (but the new lid will fit on the old housing).
Should be plenty of the early generation 1740s around, they would be fine for what your looking for.
The updated housing and lid had nothing to do with the "track overheating" issues of the Z06 (that is an engine radiator airflow problem), it simply improved an airflow distribution issue to the two rearmost cylinders on the LT4.
In reality, by the time you scrape up all of the parts to make the system work on an LT1, might be easier it just get an off the shelf system which includes belt drive, coolant lines, front radiator, etc.
Old 02-10-2019, 08:48 PM   #13
ShizzySupra
Drives: 16' Camaro 2SS
Call your local off the shelf system distributor and have a much better system overall with warranty.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 02-10-2019, 11:22 PM   #14
Drsagacity
Drsagacity's Avatar
That's great information. Much appreciated. Believe me, I wanted to go with an off the shelf solution. It's possible I will do that later if I decide to go any further. But since this is the daily driver, I am very restricted with how far I can go...
TBD performance
