Old 02-08-2019, 03:06 PM   #1
weatherman71
Drives: 2019 Camaro 2SS
Camaro noob here.... A question
This is my first Camaro.... im from the Mustang world. I just got a 2019 2SS with the NPP exhaust. I want it a little louder without changing factory mufflers. What are my options?
weatherman71 is offline   Reply With Quote
Old 02-08-2019, 03:11 PM   #2
HyperM3
Drives: 2017 Audi A4
Are you willing to dig into the exhaust at all?
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/BMS JB4/CTSTransMount/034Intake/034Strutbrace/034RearSwayBar/034RDPipe
HyperM3 is offline   Reply With Quote
Old 02-08-2019, 03:12 PM   #3
SliChillax
SliChillax's Avatar
Drives: Camaro ZL1 A10, F-Type R, RR Sport
Second cat delete, some kind of X pipe / H Pipe, fuse pull, headers?
SliChillax is offline   Reply With Quote
Old 02-08-2019, 03:13 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
longtubes
Old 02-08-2019, 03:14 PM   #5
weatherman71
sure.... just didnt wanna change mufflers if i didnt have to
Old 02-08-2019, 03:15 PM   #6
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
Pulling Fuse #51 keeps the NPP valves open 100% of the time. Also pulling the foam out of the sound tube. https://www.camaro6.com/forums/showthread.php?t=501964
If these free easy mods don't do the trick, you will need to start modding the exhaust by deleting the secondary cats with a Borla 60606 or having an exhaust shop weld in pipes in their place. You can combine this with an axle back of your choice. There are options available that retain NPP. They can get rather pricey.
A lot of people go straight to headers for more volume and actual performance increase but these require a tune and will void your warranty.
lgarrison34 is offline   Reply With Quote
Old 02-08-2019, 03:17 PM   #7
HyperM3
Depends on how much you want to change. Like others have said, you can go as far as changing headers, cat deletes etc. Basically getting a whole new aftermarket exhaust while youre at it. You can try simple things first like an x-pipe resonator delete. Thats easily reversible if you dont like it.
13 HD FatBob
Old 02-08-2019, 08:49 PM   #8
GroundhogSS
GroundhogSS's Avatar
Pulling the F51 fuse helps, and you can go back if you ever need to. After a few thousand miles and/or a few trips on the highway, they get louder. You get more soot on the outside pipes since most of the exhaust comes out there.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 02-09-2019, 12:12 PM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Welcome.
I've moved your thread to 'Engine/Exhaust/Bolt-ons'
-DG
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 02-09-2019, 01:56 PM   #10
chaospiece
Drives: 2018 SS, 2016 GT
Electric cutouts. Any will do, you don't need the ridiculous $400 ones. They're basically muffler delete you can close when you need too or adjust the volume by partially opening them. I suggest adding after the xpipe right before the NPP case, don't do it before the crossover like most people think it should be or it'll sound gross.
https://www.instagram.com/p/Bls_1aun...=1dn952fumewer
chaospiece is offline   Reply With Quote
Old 02-09-2019, 05:14 PM   #11
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
I have a used set of NEP full cat delete pipes. PM if interested. They are in the member classifieds.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 02-10-2019, 01:13 PM   #12
dfxrte
Drives: 22 ZL1 M6
deleting the muffler one of the main reasons to remove factory exhaust. the thing is massive
dfxrte is offline   Reply With Quote
Old 02-10-2019, 02:28 PM   #13
Deputy Dog
Drives: 2017 Super Sport Cam.
Put it in Track Mode.
Deputy Dog is offline   Reply With Quote
Old 02-10-2019, 02:57 PM   #14
Bobkd
Drives: 2018 1ss, 2021 silverado HD
Louder inside or outside? If you want to hear the exhaust a little more, leave the backseat down.
Bobkd is offline   Reply With Quote
