Old 02-07-2019, 09:25 PM   #1
Wheat_Fed_SS
Wheat_Fed_SS's Avatar
Drives: 2016 Camaro SS
Msd 2 step on automatic
Anyone here managed to get their 2 step to work on their automatic? If so how did you set it up because their are literally no instructions on what to do... I got them plugged in the coil packs and the wire running through the firewall and tried to set it up on a switch but all it does is light red when I go to start it and then it turns off but won’t turn back on. Need help..
Wheat_Fed_SS is offline   Reply With Quote
Old 02-08-2019, 01:21 PM   #2
Buckscamaro
Buckscamaro's Avatar
Drives: 2016 ss camaro
We got one to work on an M6 car, check out the link below. I think you can get it to work the same way but instead of the clutch hook up to a momentary switch. That’s the only way I think you may be able to pull it off
https://youtu.be/r9xY3GzmYWQ
You tube channel:
G's footage
https://youtu.be/VCnanR8qsNg
Instagram: boogieman_racing
Buckscamaro is offline   Reply With Quote
Old 02-08-2019, 01:47 PM   #3
Wheat_Fed_SS
I had to take a break from it as I was getting frustrated. So I slept on it and cleared my head and found out what the problem was. I had a bad switch. So I went and got a new one and bam.. we are good to go.. buttoned up everything and we are good to go. What did you set yours on? I tested it at 2000 and it’s sounded ok but I figured I could go much higher
Old 02-08-2019, 01:48 PM   #4
lokitwitch04
Drives: 2017 Camaro SS 2SS
I'm putting mine on a button. I'm also an auto car.
lokitwitch04 is offline   Reply With Quote
Old 02-08-2019, 02:04 PM   #5
Wheat_Fed_SS
I just used a rocker switch.. was pretty simple to install just frustrated me when I couldn’t get it to work when all it was was a bad switch. I wanted to use a pressure switch on some spaghetti cable so I can hook it above the knee bolsters and just drop it when I take off but I couldn’t find local and my butt being impatient just went with a switch
Old 02-08-2019, 03:17 PM   #6
Wheat_Fed_SS
Got it all buttoned up and zip tied the wires up... love it already! Set it to 2800 rpm..
https://youtu.be/eWn5OXAFc7Y
Old 02-08-2019, 03:43 PM   #7
Laststandard
Drives: 2018 1SS 1LE
Maybe I'm out of the loop, but what's the benefit to having a 2 step on an auto?
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 02-08-2019, 09:45 PM   #8
lokitwitch04
What other mods do you have?
Old 02-08-2019, 09:48 PM   #9
lokitwitch04
It workes better than the factory launch control. To load up the converter. Factory launch control in the auto is garbage.
Old 02-09-2019, 12:57 AM   #10
Buckscamaro
I set mine at 4K but that’s because I have g force axles and run a bias ply. Never hooks but yeah lol
You tube channel:
G's footage
Old 02-09-2019, 07:48 PM   #11
KonigWolf
Drives: 2016 2SS A8
Are you going to do a launch video with the 2step?
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 04-09-2019, 10:22 PM   #12
the.beasst
somebody explain to me if the 2 step box needs a separate switch to be activated? i want to use a spaghetti cord to actually use the 2 step but it’s not wanting to work right. help?
the.beasst is offline   Reply With Quote
Old 07-10-2019, 11:28 PM   #13
Alvin
Alvin's Avatar
Drives: 2017 Camaro 1SS
I just installed the MSD 2Step. How much RPM would be the loudest?
Alvin is offline   Reply With Quote
Old 12-12-2019, 10:24 AM   #14
Choda
Drives: Turbo 6.2
Im getting a msd 2 step for Christmas from the ol lady. I have an A8 and will be using the brake pedal as the power with a toggle to arm. I did this with my old turbo silverado and loved it.
splice into Brake pedal power - micro toggle switch - msd box.
when you want the 2 step, flip the little switch on and press the brake. when you are brake boosting sitting on the 2 step and then let off the brake, it will disengage the 2 step and you're off to the races. no need to use your feet and hands to launch correctly. I'll document it so you guys with autos can see how I do it. I never liked the idea of holding a button with your finger along with using booth feet when trying to launch a car.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
