| View Poll Results: Choice of skip shifting elimination | |||
| I don't need an eliminator, just adjusted my driving |
56 | 64.37% |
| Yes I use an skip shift eliminator |
27 | 31.03% |
| I use Muzzy's |
3 | 3.45% |
| I use Michigan Motor sports |
1 | 1.15% |
| I use Phastek skip shift eliminator |
5 | 5.75% |
| I use Casper eliminator |
0 | 0% |
| I use another brand (mention which in comments) |
6 | 6.90% |
| Multiple Choice Poll. Voters: 87. You may not vote on this poll | |||
Thread Tools |
![]() ![]() ![]() ![]() ![]() Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Hi Guys,
I just came back to the Camaro pack, traded my automatic transmission '14 Corvette Stingray Z51 for an awsome looking dark gray '16 Camaro SS, couldn't resist of going back to the shifter. The only thing that I find bothering is the skip shift. I read on the forum that some of you are using a skip shift eliminator or just adjusted your driving technique. I would like to see which is the trend with a fast survey. Also could you please mention if you have any issue like a "check engine" while using those devices. Thanks for sharing!
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport Last edited by Bosse'sBoss; 02-07-2019 at 08:13 AM. |
![]() Drives: SS Join Date: Dec 2015
No CEL with my SLP Skip Shift Harness
![]() Drives: 16 1SS M6 Black -previous 00 Z28 M6 Join Date: Oct 2018
I absolutely needed it on my 4th gen it was so intrusive, but on my 6th gen I've found, even with the message displayed, it rarely actually forces me to shift into 4th.
![]() Drives: 2016 Camaro 1SS, Jet Black, M6 Join Date: Sep 2018
As long as you get over 20mph before shifting to 2nd all is well. Even with my AWE catback it's not overly obnoxious.
2016 Camaro 1SS | M6 | Jet Black | Roto-Fab Dry w/SND Tube Delete | AWE Touring Cat-Back Exhaust |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I've had one in all my Camaros because quite frankly, if I wanted the trans to decide for me when to shift i would have bought an auto. That said, SSE is probably more effective if you are in a high traffic area as opposed to a rural area.
![]() Drives: 2017 2SS M6 FIFTY @51fifft Join Date: May 2017
To each their own but I never get the SS but I drive pretty aggressive. If i do it's because I want to and even then it's hard.
#7 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
I tuned it out when i went E85, so no warning on screen ever.
However before tuned it only happened when turning off a red light... just it a little more gas pedal and thats it. To me the sign was more bothering than the fiscal mechanism. When ever it threw you to 4th, you just pop it out and place it in second.
Florida High Performance: H/C Whipple LME 377 900WHP
#8 |
![]() Drives: 19 SS 1LE Join Date: Nov 2018
It happens rarely to me and I am nannying the breakin too. When it does happen you just push the stick right like going to sixth and then back left and you can put it in second. I thought for sure I would eliminate it, but it’s unnecessary
#9 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
![]() The stock tune disables skip-shift above 19 mph.
#10 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
I installed mine at 160 miles. couldnt stand it.
#11 |
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
If skip shift is a problem.... you're driving like a granny. Get on it!
#12 |
![]() Drives: 2018 Camaro 1SS 1LE. Red. Join Date: Mar 2017
The car is my daily driver, and depending on the time of day I hit all kinds of wierd semi-urban traffic. Slow to a turn and then merge aggressively, etc. But then find yourself behind a hypermiler.
I have learned instinctively to go 1 to 3, which doesn't lock, on my new 1ss 1le. Before it was totalled my 1ss '17 early on caused me maybe two crap your pants situations when I wanted to go to second and couldn't. If you learn the car it's fine. If you are a lifelong manual driver, and/or regularly drive pretty different manual transmissions it can be downright dangerous for someone new to the car. It's not how any manual is supposed to work. You can adjust over time. |
#13 |
![]() Drives: 2018 Camaro 2SS (EU) Join Date: Jul 2018
Interestingly, Euro cars come without skip shift from the factory.
2018 EU 2SS - 6MT - Black GBA - Recaro seats - NPP - MRC
Black Bowties - GM Fuel Door - Black Camaro Fender Logo - K&N Air Filter - Katech ported TB - GM Dark Tail Lights - GM ZL1 1LE 3rd Brake Light - HRE FF04 - Eibach Springs |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Agree on the 4th gen needing one. Had one from SLP and really helped my ‘98 SS but I don’t see the need for one on my ‘16 SS. It has come on a few times because I wasn’t going fast enough. I didn’t have one on my 2010 SS either.
