Old 02-06-2019, 02:05 PM   #1
EdTheEnthusiast
Drives: 2016 Hyper Blue Metallic 2LT v6
Any 2019 Camaro A8 or A10 Shudder?
This thread might be too soon of a post but has anyone with a 2019 A8 for the LS, 1LT, 2LT, 3LT or anyone with the A10 with the 2019 SS, 2SS trims have had the transmission shudder occur?
Does anyone know if GM has fixed the tune for the torque converter for 2019 model years with the A8 transmission?
(Yes I do know that the only 2019 models with the A10 available are the SS trims and the ZL1, otherwise all other trims are A8 if people do not choose to get a manual).
Thank you very much for anyone who will be able to give insight.
EdTheEnthusiast is offline   Reply With Quote
Old 02-06-2019, 03:26 PM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
From everything I've seen and heard, they have not fixed the issue for the A8. But ill be curious as well to hear if others have heard differently
HCI2000SS is offline   Reply With Quote
Old 02-06-2019, 05:49 PM   #3
Riker
Drives: 2017 Camaro 2SS A8
A recap on the A8 issues:
First - GM/Al Oppenheimer stated some cars were getting bad fluids at the factory which caused the shudder. The torque converter clutch was becoming burnished and damaged and would eventually need replacement. The fix was to do a triple flush with auto fluid and send you on your way.
Second - If you still had a shudder after the triple flush, you received a new TCC because it means your clutch became too damaged/burnished to operate correctly.
Third - Late last year they stated to dealers to halt all new TCC replacements due to shudder as they found even the new TCC's are still burnishing. They said they will have a fix by Q12019. They now have the new TSB 18-NA-355 in which there is now a new fluid to be used along with some sort of flushing machine/kit. The previous Mobil 1 fluid was too hydroscopic and was holding too much water and ruins the properties of the fluid and caused the damage/burnishing. The new fluid, Mobil 1 Synthetic LV ATF HP, is supposed to not hold onto the water and come off through heat as originally intended. Part numbers for the fluid are 19417904 for 55 gallon drum and 19417577 for quarts. All dealers should have the tools/fluids by March 2019.
So now we have to wait as see if that truly is the root cause and if this new fluid resolves the issue.
TPNS5F
7/11/16 - 1100 - Ordered 2017 2SS at dealer
8/7/16 - Order requested to be cancelled
TRBTXD
8/9/16 - 2000 - New order placed
8/10/16 - 3000
~8/16/16 - 3400
9/20/16 - 6000 Delivered to Customer (That's me)
Riker is offline   Reply With Quote
Old 02-07-2019, 10:00 AM   #4
SSport16
SSport16's Avatar
There will no "true" fix for the A8...they will milk it as long as they can until the A8 gets replaced by either the 9 speed in some vehicles or the 10 speed in others.
Old 02-07-2019, 10:44 AM   #5
MarkZ
MarkZ's Avatar
Drives: 2016 Camaro RS 2LT
New 2019 fluid is supposedly in.... I will see on Monday.
Mark
MarkZ is offline   Reply With Quote
Old 02-07-2019, 11:02 AM   #6
wrankin
Camaros Of Northwest Ohio
Drives: 2023 Red Hot 2SS 1LE
I have a copy of TSB 16-NA-175 that includes Camaros with Trans RPO M5T and M5U that states this: Service Procedure - Important: Requires Mobil 1 Synthetic LV ATF DEXRON HP (GM Part No. 19353429, in Canada 19353430).
The TSB was dated Feb 27, 2017. Does anyone have a GM Part number on the supposedly new fluid?
EDIT: Sorry, the GM part number for the new fluid is 19417577. Missed it.
Thoughts?
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 02-07-2019, 11:06 AM   #7
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Your vehicle has to be experiencing the shutter or they will not replace the fluid just because the new fluid is out. The dealerships did not get the new fluid until January from what I was told.
dmcmahan60 is offline   Reply With Quote
Old 02-07-2019, 11:19 AM   #8
MarkZ
MarkZ's Avatar
Thoughts?
Bill
Its in one of the above posts, and confirmed.
Mark
Old 02-07-2019, 11:26 AM   #9
wrankin
I did have the shudder in September October 2017 and they used GM Part No. 19353429 to do the flush and not the 19417577.
Bill
Old 02-07-2019, 11:29 AM   #10
wrankin
Got it - thanks. Edited my post to reflect that info
Bill
Old 02-07-2019, 12:51 PM   #11
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Bill
Mine was done in November with the same and the shudder has not come back, yet.
Old 02-08-2019, 03:48 PM   #12
OneMadSS
OneMadSS's Avatar
Drives: 2011 Camaro SS
Took my 2017 Camaro SS in to chevrolet for a trans flush today and they said the "new" fluid came in that should fix the shudder. I will give you guys an update later to see how it turns out.
OneMadSS is offline   Reply With Quote
Old 06-29-2019, 04:26 PM   #13
PhantomV8
PhantomV8's Avatar
Any update?
PhantomV8 is offline   Reply With Quote
Old 06-29-2019, 05:11 PM   #14
Mgsouthwest2001
Mgsouthwest2001's Avatar
Drives: 18 Camaro 2SS 8A Hyper Blue
My 18 SS had the shudder back in April. I had the new fluid flush done. Now a little over 2K miles later, the car is still fixed. No more shudder at least for now.
18 Camaro 2SS: Hyper Blue 8A
Mgsouthwest2001 is offline   Reply With Quote
