TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 02-05-2019, 04:21 AM   #1
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Question What trans coss member and mount for CTSV 6L90E?
I picked up a 2012 CTSV 6L90E to replace my 6L80E in my 2010 Camaro SS and need to know what trans cross member and mount will work.
Anyone know?
PN #'s?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 02-05-2019, 07:29 AM   #2
TY 2010
Drives: 2010 CAMARO
I believe the GM part number for the crossmember is 20952438 and the trans mount is 20952440. You will also need a driveshaft goes from 6L90E to SS differential. The stock drive shafts will not work. I have done this swap. I just pulled my DSS 4" driveshaft out. Let me know if you are interested it will be for sale.
TY 2010 is offline   Reply With Quote
Old 02-05-2019, 09:38 AM   #3
John_C
LSx FTW!!!
John_C's Avatar
Thumbs up
Thanks for the PN#'s!
I already ordered the 3.5" DSS drive shaft.
2010-2015 Camaro 3.5" aluminum driveshaft (with a 6L90 CTS-V Trans and stock differential ONLY).
Item# GMCA11-A7-V
http://www.driveshaftshop.com/domest...ferential-only
HP Tuners VCM Suite
Old 02-05-2019, 11:20 AM   #4
TY 2010
Drives: 2010 CAMARO
You will be happy you made the swap. My 6L80 died at about 750 Hp and the 6L90 is holding up great at over 1000. The DSS driveshafts are awesome. Good luck
Old 02-05-2019, 03:00 PM   #5
John_C
LSx FTW!!!
John_C's Avatar
Who tuned it?
Seems like the tune is part of the recipe for making the 6L80 / 6L90 last.
HP Tuners VCM Suite
Old 02-05-2019, 05:04 PM   #6
TY 2010
Drives: 2010 CAMARO
I use Matt Sorian at MS Tuning.
Old 04-15-2019, 07:15 AM   #7
John_C
LSx FTW!!!
John_C's Avatar
Exclamation
For future reference if others try this swap, the ZL1 and SS corss members might have different PN#'s but they're in exactly the same.
The ZL1 and SS cross member to CTSV 6L90 won't work without some custom fab work.
The CTSV tail has the mount holes farther back than a SS / ZL1 cross member mount.
HP Tuners VCM Suite
Old 04-15-2019, 07:19 AM   #8
John_C
LSx FTW!!!
John_C's Avatar
Stock 6L80 and you can see how far forward the mount is...
HP Tuners VCM Suite
Old 04-18-2019, 11:09 PM   #9
John_C
LSx FTW!!!
John_C's Avatar
My shop guy made a mount...
So I don’t do anything half ass lol
I’m over at a buddy’s and we are gonna cut your transmission/mounting plate on his plasma table so it’s 100% and if anyone needs one later down the road they will be available.
Probably spent way more time than I should have on this but it fits beautifully and it is serviceable so it uses the stock mounts no modifications.
If something breaks it can be replaced and this piece swaps right over.
HP Tuners VCM Suite
Old 07-27-2020, 09:57 PM   #10
SRMGT
Drives: Auto V8
Hey I know this is from last year but I'm doing this swap and would love to have one of those adapter plates your buddy makes if they are still available. Any help is much appreciated!!
SRMGT is offline   Reply With Quote
