Old 02-04-2019, 05:57 PM   #1
mgwarlock
Nightfall Gray Blackout
mgwarlock's Avatar
Right Led tail light not working
Is this a bulb replacement or I have to replace the whole piece because it’s led?
Try to find a thread but no avail....thanks
mgwarlock is offline   Reply With Quote
Old 02-04-2019, 08:21 PM   #2
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
whats not working? The turn signal or nothing lights up?
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 02-05-2019, 12:07 AM   #3
JGiovando
Drives: 2018 1SS 1LE HBM
Are your side markers working? Had a corroded rear side marker due to water exposure and it shorted out the front side marker and tail lamp on that side. Replaced side marker and all good. Hope it's something simple like that, because only the reverse light bulb can be replaced in the assembly. Good luck.
JGiovando is offline   Reply With Quote
Old 02-05-2019, 09:27 AM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
You have a blown fuss, its part of the fuss's that run the BCM in the car, its not marked as a tail light fuss.
Here is a link when we had the drivers side go out. https://www.camaro6.com/forums/showthread.php?t=541225
2SSRS@Gen5diy is offline   Reply With Quote
Old 02-05-2019, 10:51 AM   #5
KirkH
I also had water corrosion on the LED resistor that caused my tail light to malfunction.
Old 02-08-2019, 07:18 PM   #6
mgwarlock
mgwarlock's Avatar
Thanks guys....and yes it’s the led side marker busted that cause the rear lights to go out!
I disconnected the side marker and boom it’s working.
Old 02-08-2019, 07:56 PM   #7
JGiovando
Thumbs up
Glad you found a simple solution! I know I was stoked when I figured mine out. Of course that was after 2 nights of frustration including replacing the dark tail lamp with the stock tail lamp, pulling all fuses, etc. all to no avail until I checked that damn side marker
