Old 02-04-2019, 03:54 PM   #1
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
I need step by step instructions to replace passenger mirror
I need step by step instructions on replacing my passenger door mirror. I don't have a shop manual. My camaro is a 18 1SS. I hit something and broke the mirror off. Thank you for your replies.
Corvette_Mike is offline   Reply With Quote
Old 02-04-2019, 03:55 PM   #2
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
grab it.. pull it... rip it off.... and glue on the new one.
lol JK. I'm sure GM might have a diagram out there for you.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 02-04-2019, 04:57 PM   #3
kaz1961
Drives: 2018 RS
Are you replacing the whole assembly or just the glass?
kaz1961 is offline   Reply With Quote
Old 02-04-2019, 05:29 PM   #4
Corvette_Mike
The whole assembly
Old 02-04-2019, 07:09 PM   #5
Corvette_Mike
How difficult is it to remove the door panel?
Old 02-04-2019, 07:11 PM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
hit up lethal hammer he can help probably or already has a video on it
Old 02-04-2019, 10:10 PM   #7
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Smile
I was in your exact shoes when I got my '16. Passenger mirror replacement needed, I'll try to be as most help as I can.
First, watch Lethal's Video. You just need to familiarize yourself with how to remove the door/where all the clips are. I wouldn't be surprised if some of your clips get broken in the process, I bought 2 types of clips from O'Reilly's that fit practically perfect.
Once you've got the interior trim of the door taken off, disconnected as well if you want for an easier process. I would disconnect the mirror connector and push through the wiring so that the black portion that is holding it against the door is inside the door itself. You need to pry off the black gasket and clear tape (some people cut through theirs, I just pried it off and reinstalled afterward). Reference these pictures for the location of the gasket/clear tape and the mirror connection.
There are 3 nuts holding the mirror assembly in place once the gasket and clear tape is taken off, what I did and another user suggested on this thread was to have an extension along with a sturdy piece of paper rolled up underneath the extension bit so that the nuts don't fall in the door.
When you have all 3 nuts off, you can pull the mirror assembly completely off. If you have a new mirror assembly then it's as simple as putting that in and pushing the wire through/connecting the wire. If you're trying to open up the mirror for small parts replacement, I took a picture of my broken mirror that I left open Opened Mirror.
Let me know if you need help or any questions
Old 02-04-2019, 10:25 PM   #8
KirkH
Here's my thread from the DIY subforum on replacing the outside mirrors
https://www.camaro6.com/forums/showthread.php?t=483340
EDIT: I see this thread was referenced above.
Old 02-04-2019, 10:31 PM   #9
Bumbleboy92
Long hauler
I wanted to say thanks to you, I wouldn't have been able to do my mirror replacement without your thread haha
Old 02-04-2019, 11:30 PM   #10
KirkH
Happy to help!
Old 02-04-2019, 11:51 PM   #11
Corvette_Mike
